need a place in my area to look at my wiring (Washington)
podge1
Post by podge1 »
hi, iv been having a terrible time getting my car sorted out, fuel cut keeps coming in too early, and dash boost guage always reads + (max), i investigated the wiring near ecu, which was all taped up. i removed tape, and oh my god, loads of wires just twisted together, 3 connected to one ect, there is obviously shorts, mixed up wires all over. the prev owner has made a right mess of it. :(
as i dont have a clue what goes where , and what to do, i need someone who knows what they are doing, to have a look for me. if anyone could do this i would pay them obviously, or recommend me somewhere to take it who would know, i would be very grateful.
i live in washington, near sunderland/newcastle.
please help!
thankyou
p
PW@Woodsport
Re: need a place in my area to look at my wiring (Washington)
Post by PW@Woodsport »
podge im local and will have a look at it for you,bring the car to the petrol station at haswell plough (near peterlee) between 9am and 4pm mon-fri and lets see if i can sort you out,just let me know what day you are coming if any,paul.
podge1
Post by podge1 »
hi, thanks for reply! thats really very nice of you mate. im on nites next week, so if i came on monday about 1:30pm would that be ok? do you work at the garage?
thanks again paul! :D
PW@Woodsport
hi mate,i run an MR2 specialist garage,mainly mk1's but the odd mk2 comes here....i will have a good look at it for you on monday around 1:30pm ,might not be able to sort it straight away if the wiring is butchered,talk to you monday.
philz
Post by philz »
Where exactly is your garage Paul? (I'm from Peterlee originally so I know the area fairly well)
Do you do bodywork too as I need my front bumper spraying after some fool reversed into it and cracked it (only a tiny 1" crack but I like to have my bodywork to be perfect).
I should be up in the North East next weekend for the Radio 1 weekend thing so if you happened to work on a Saturday/Sunday that would work out perfect.
podge1
Post by podge1 »
brilliant!
i shall see you there, at 130. thanks so much! :D
PW@Woodsport
phil i dont work weekends unfortunately,the garage is in haswell plough about 3 miles from peterlee...yep i do paintwork to a high standard , give me a ring if you need to chat 07951304712.
philz
Post by philz »
That's a shame as the only times I can really make it back up to the North East is on weekends :(
Never mind though, I'm sure I can find a reputable bodyshop around here.
PW@Woodsport
hello mate,ive found that wire for you,its on block A pin number 5...its a green with white stripe wire,this is your check engine light.....but i was wrong about its operation,it doesnt become live to make the dash engine management light flash,it becomes an earth and does it that way....so you will need to shove a test bulb onto a battery live,the one i used on your starter motor relay will do and join the other end onto pin 5 blockA green/white.....bridge out TE1 and E1,switch ignition on and see what the test bulb does...get back to me if you have a problem or with the error codes.....
gtech
Post by gtech »
How did it go Paul, did you manage to solve his Boost problems.
Graeme
Berk Tech IC, Berk Tech Downpipe, Berk Tech Exhaust, ARC Induction System, DevilsOwn Water/Meth Injection (Pre & Post turbo). TRD Cold Pipe, EMS Powered Digital Boost Gauge, TRD Strut Braces, Innovate O2, Blitz SBC i-color EBC - "ARCH ROLLER FOR HIRE"
PW@Woodsport
no not yet graeme,no check engine light at all...so until we get that working theres no clues as to whats going on....its hitting fuel cut at 7psi which is odd to say the least,shouldnt happen until 12psi...thats regardless of wether the boost pressure sensor is connected or not!! :shock: i suspect theres an ecu fault that the previous owner has covered up by removing the dash bulb....so he wont know for sure until thats fixed.
gtech
Post by gtech »
Nightmare situation, buggers things up slightly when previous owners go chopping bits out and pulling important indicators, obviously had the buyer seen the light flashing then maybe the sale would not of gone through or at least affected the price...buggers.
so its going to be a case of checking that check light wiring all through the system??? poor bu88er.
He's got the best man on the job, thats for sure ;-)
PW@Woodsport
i think the light is the least of the problems,i have a feeling the ecu might need replacing,i cant for the life of me work out why its hitting fuel cut at 7psi,thats unheard of....
podge1
Post by podge1 »
hi, firstly thankyou for going out of your way to look at my car, it really is very kind of you to help me. and im also learning a lot of things too along the way! i shall see if i can borrow one of those gadgets you used, from work tonight and il see if i can get any codes out.
looks like its going to going to be a night mare, but its nice to know when your stuck, theres good people willing to give you advice!
il let you know what i find
cheers paul
PW@Woodsport
you're welcome mate,lets see if we can get to the bottom of it.
podge1
Post by podge1 »
hi again, could only get hold of a volt meter, my mate said it would work the same. i checked for codes the way you said but dont think it worked, wasnt getting any "flashing" signals. im going to try and get a hold of bulb. and try again. il let you know.
PW@Woodsport
no probs,remember the ecu isnt outputting a positive voltage,its outputting an earth to make the dash bulb flash so you will need to wire a bulb to + and test the pin i gave you with the - end of the bulb.
podge1
Post by podge1 »
hi again, wired a bulb up today, and done test like you said. put one end on live starter relay, and other on the 5th pin (green) no flashes, bulb just lit up constantly... :(
what does this mean?
thanks.
p
PW@Woodsport
right,that confirms an ecu problem...if you had a bulb connected to live on one wire and connected to that green wire on pin 5 block A and it just stayed lit permenantly then it can only be a faulty ecu.....i bet if you take your clocks out the check engine bulb has been removed by the previous owner....replace the ecu mate,theres often one on ebay or one of the lads on here might have one for you.
podge1
Post by podge1 »
thanks paul, thats great. sounds like an easy fix!
have a good weekend mate.. :D
Return to “Electrical”
