help wanted again!
not sure if this should be electrical, anyways;
i have a 2002 mk3 import that has failed its vosa esva test on the speedo.
(and only the speedo, darn more fees to follow.
) i bought the car and was told it had been converted however it appears that all they did was change the face of the dial to a uk one without doing the clever stuff.
the dial is a white faced one with a maximum of 110mph in the big numbers with km/h in the inside.
now as this car had cost me much more than i wanted to spend, i will never agian touch an unregistered car!
can anyone offer advice on how best to
(and cheaply) bring it into line?
the reading is well below what it should be e.g.
reads 70mph actual speed 95mph
(by tester on rollers.
thanking you in advance.
