I've got a 1992 Rev 2 MR2 import 3sge that had been sitting for 5 or so years before I got hold of it.
The car won't start but turns over well with a good spark, im 99% sure its fuel pump but the previous owner told me it did run once when it was removed from storage and then stopped
It does have an immobiliser but this seems to be working i.e clicking the dash lights on when you wave it around.
I've taken the union off the top of the fuel filter and then tried the following:
bridged the diagnostic ports
Put a volt meter on the fp terminal and there is 12v
Removed the centre trim and given a 12v source to the grey connector with the thick wires
Still no fuel coming out of the top of the filter.
Im assuming this means the pump is caput but just encase i've been doing the above wrong as it looks like a horrible job if its not needed!
Thanks in advance for any help.
