Yeah, I had been heel-toeing since I had my first car, although every car has different ratio's, so it can take a while to get right.
Easy enough to practice on an empty straight road.
This should only be done on the straight/lead up to a bend though, changing mid bend is asking for trouble.
Sure there's loads of info on the web if you want to learn the basics
clicky here![](./images/smilies/spacer.gif)
for example)
I have moved from a CRX SiR with an 8k rev range, so there is a huge change in engagement points for each downshift.
Shifting aside though, the MR2 is such a different car to drive than the FF layout I am used to.
The first time I drove it a little harder I couldn't believe how light the front end felt, and how planted the rear felt, really strange.
It will definately take a lot longer to be able to drive it well than my last car, trying to keep in mind where the weight is, and how not to un-balance it.
With an FF you can just get the right gear, and give it some throttle then just feather it to control the understeer.
Not the case here!
I think, driven well with experience, the MR2 could definately be a quick car around the bends.
This is kinda why I chose the MR2 Turbo, I had thought of an imprezza, but a 4WD layout is so easy to drive quick, I wanted something I could improve my driving with really.
Knowing how much throttle and when to apply it mid-bend is where a lot of the skill must lie though, and I guess this is just experience.
Knowing how hard to push it is the scary thing though, and I don't think I want to experiment with it on a B-road
- I think maybe a track-day could be in order.
