i am still in the process of installing this and instead of asking the odd specific question i hope to group them all here so anyone with experience of fitting WI please pipe up!
i've a rev 2 turbo with TD05 and a Greddy IC.
first off i bought the Aquamist system.
![Image](https://i.imgur.com/anohQsM.jpg)
i'm doing this at weekends when it's not raining
i removed all the carpetting from the boot to expose the bulkhead.
drill 4 holes in the bulkhead for the bracket.
![Image](https://i.imgur.com/HntQrIa.jpg)
![Image](https://i.imgur.com/j1DeePl.jpg)
![Image](https://i.imgur.com/PjHAie7.jpg)
then fit the tank and then the water level and feed to the pump:
![Image](https://i.imgur.com/jv0GG2A.jpg)
![Image](https://i.imgur.com/lMVaxjN.jpg)
![Image](https://i.imgur.com/2wssTHe.jpg)
then 4 holes for the pump bracket:
![Image](https://i.imgur.com/ieqIvji.jpg)
then install the pump.
![Image](https://i.imgur.com/X1Vs4xm.jpg)
![Image](https://i.imgur.com/JW5wuJ5.jpg)
i am test fitting everything before i put the carpet back in.
i have fitted some tubing and located where the FAV
i'm at the stage where it's time to start wiring up the control unit.
4 way connector:
red- fused
- switched positive
(red lights ignition)
black- ground
white- ground
purple- lights
all at fuse box in compartment or engine bay.
ECU Grey RJ48 Connector:
red- to IGT
(Igniter) switched positive
green- to
#1
(Injector) pulsed ground
(hopefully, will check with multimeter)
blue- to PIM
(Map sensor) 0-5v signal wire.
these wires are just joined'Y'
failsafe:
cut TPS wire(turbocharging pressure VSV):
white- to ECU side
brown- VSV side
all these are fine except i can't find a pulsed ground injector wire.
![Image](https://i.imgur.com/BWWYyi0.jpg)
i would like to locate all wiring before i continue and it's just this that's holding me up.
also if you have a boost controller it's likely that your VSV is disconnected.
i'll be populating this thread as i go so anyone with any good info please contribute!
![Smile :)](./images/smilies/icon_smile.gif)
