Hi folks...
Just had the ST205 CC conversion done ... and what a difference!!
However, I'm getting the engine fan light coming on, as the stock intercooler and fan have been removed. Short of either buying a Revision 6 engine fan kit, or removing the bulb in the dash (!), what's the preferred way of removing the light?
Cheers,
Johnny
Chargecooled 1995 GTS[/code]
Engine warning light fan after ST205 Chargecooler conversion
Re: Engine warning light fan after ST205 Chargecooler conversion
If you have a ST205 cooler, you can Keep the old intercooler to strap the fan to.
The engine bay still wants that fan to keep the engine bay cool !!
If you must, I guess you could just unplug the engine bay fan control ECU (to the right of the engine ECU) - check the wiring diagram... but I'm sure it only controls the engine bay fan (and drives that warning light)
Paul
Paul
what u want to buy is a n/a fan adaptor plate, so u old fan bolts down in the corner
