As title really..
Should I treat as running in a new engine and work through mineral 200 miles, semi 300 miles, then a quality fully ?
The engine has been sat for 7 years and only turned over once by hand a few weeks ago.
Open to any thoughts and suggestions
Thank you
[Mk2] [Turbo] oil for run in after 7 years no use.. turbo
- IMOC Moderator
Re: [Mk2] [Turbo] oil for run in after 7 years no use.. turbo
treat it no different. It's done the miles, the rings are bed into the bores.
Fantastic..
What's preference for a mildly modded tubby lump these days?
Happy to spend a couple of hundred a year
If it has sat for that long with out turning over I would
Drain oil and fuel + filters
Replace
Pull the leads off. Crank a few times to allow the oil to circulate and stop unnecessary ware
Replace
will do Ryan. thank you
Did it start??
I'd want to change plugs, dizzy cap rotor etc. Timing belt as well.
i haven't put the engine in the car yet buddy.
tubbychat3 wrote:i haven't put the engine in the car yet buddy.
