Last night I came home from work (in the dark) on my bike and as i pulled into my drive i noticed the brake lights on my 2 were on. Now I havent driven it since the Monday and again parked it in the dark so would have noticed the brake lights still on if they had have been then.
So last night I grabbed a torch, initially thinking of pulling a fuse or battery terminal. When i illuminated the footwell I found bits of plastic there!
Turns out there is a plastic stop on the pedal that pushes the brake light switch and mine had decided to disintegrate and fall out whilst parked. So to turn out the lights overnight I just unplugged the switch.
This morning I dug around in the garage and found a ribbed panel fixing (christmas tree) about the right size, trimmed the branches and popped it in. I adjusted the position of the switch and all fixed for now. I have ordered the correct part to fix properly but this means i can now drive the car if needed.
If this happens whilst out and about, there is an identical stop on the clutch pedal that if you have something to prise it out could be used to get you home.
Jan
Brake lights staying on FIX
Re: Brake lights staying on FIX
I used a penny to fix mine.
Had to remove the lower part of the dash and air vent without been a contorsionist.
Had to splash out again, this time a 5p coin for the alarm sensor on the engine bay lid.
- IMOC Moderator
Above the rim
Thanks its little gems of info like this that are really help to people
now you see if this had been on faceache, it would have been bro, no its not, awesome, you "no nuthink" etc ha ha
cheers again fella
Regards Brian
cheers again fella
Regards Brian
wilkie senior wrote:Above the rim
cheers again fella
Regards Brian
Yes fam this site be safe blood
- IMOC Moderator
ha ha innit
