Thanks for the reply mate.
I must admit that given the number of wires if it had become unplugged I felt there ought to be an awful lot of stuff not working.
But I'm a bit confused about what you mean by the idle-up signal for tail lights rear fogger.
I've just checked the tail lights, brake lights, fog lights, number plate lights, and indicators and all are working fine.
The aircon also seems to be working OK as the temp of the air coming out the vents on cold setting certainly seemed to drop when I switched on the air con, and the engine idle speed increased as expected.
I've never really used the rear window defogger, so I'm not sure whether you should be able to feel the window getting warm, but again the engine idled up when switched on, presumably because of the increased electrical load at idle.
I also checked what was happening engine wise with ToyoBD1, no error codes were displayed and everything looked about right.
So I took the car around the block and the speed readout on the ToyoBD1 looked pretty close to what the speedo was indicating.
I assume that that means that the ECU is getting the correct speed reading?
I'll try and take another look around in the footwell too see if there's a socket somewhere missing a plug.
I guess I could also take the glove box out to check behind that, if it's no too much of as faff.
But at the moment it's all a bit confusing.
Just to add insult to injury, I found that the speaker cables in the replacement door harness had a break that caused the speaker to die as soon as you closed the door.
More blood sweat and tears to pull two new cables through the rubber pipe between car body and door.
Even with cable puller flat spring it wasn't easy.
Some days you wonder why you even started an upgrade
Paul
