HI guys,
whilst fault finding my cam cover leak, ive found oil in my dizzy.... is there just a seal i need to replace? if so, does anyone sell a kit etc?
Ross.
[Mk2] [Turbo] oil in distributor
Re: [Mk2] [Turbo] oil in distributor
You can get bolt kit so you can torque down so no leaks
http://twosrus.com/catalog/product_info ... ucts_id=59
cheers Rich
cheers Rich
rev2rich wrote:You can get bolt kit so you can torque down so no leaks
cheers Rich
Cheers dude. May get it for my cam cover. But oil seems to have gotten into the dizzy from a seperate place? Presume the dizzy has a seal?
Ordered the bolt kit off mr2ben. Also ordered the inner dizzy seal. So can do that at the same time.
i removed the dizzy seal (rubber o-ring on the shaft)..... when i say rubber, mine felt like rock solid plastic and it flaked/snapped off in chunks when i was attempting to remove it. the new one has 100% sealed it now... cant believe i hadnt checked this before.
