![Sad :(](./images/smilies/icon_sad.gif)
Mikey637 wrote:Appradio? Hdmi and phono inputs.I run my iphone through the apple to hdmi adaptor.
Don't know if it supports native touch though
wenguin wrote:I have a Nexus 7 in my DIN slot with a stereo behind it.Charges
+ USB audio out via special Y splitter.
I opted for gluing a N7 case into the DIN hole and then painting the whole thing, cut a hole in the side for power and audio out.Other people stick the tablet in the dash permanently but I wanted removable.
Would be interested to see your end result, sheppy!
gavsdavs wrote:I have a sumicom PC in the cubbyhole in my car- very much like this
http://www.kingyoung.com.tw/S625.htm
It's a DC PC with a car ignition aware bios, so you can watch for the ignition going off and shut the machine down(so you don't flatten the battery).
Might help solve the unit if not the screen and input devices.
UK distributors and allround helpful bunch:
http://www.kustompcs.co.uk/acatalog/CarPC_Shop.html
sheppy wrote:
hmmmm, i might look into something like this, i wanted to use a laptop specifically to make use of the"sleep" function, it can sleep on the battery while the car is off.
what's the start up time like?? If it's not under 10 seconds then I could get pretty pi$$ed off with it pretty quickly haha
Dunno, mine runs linux.![]()
Takes about 5 seconds to beep to say it's powered on.
Takes another 5 seconds to go through BIOS,
Then however long the OS takes to boot- Mine is up in about a minute after full phase ignition.
Problem with a laptop is you need a rectifier of some sort to feed it the AC that the PSU uses.
wenguin wrote:if you're talking about turning the link g4 on, i'm not sure.
Gazza_DJ wrote:I guess the only remaining issue is can you make the ECU talk to the tablet over USB or Bluetooth?
