im re-attaching my grounds and wanted to ensure they're right.
Anything look obviously wrong?
Also I've got this one loop ended ground which attaches to the body of the car, cant figure out for the life of me where the looped end goes, Any ideas?
[Mk2] [Turbo] Wiring ground confirmation
Re: [Mk2] [Turbo] Wiring ground confirmation
First pic isn't ground, it's battery positive.
Second pic is not stock but good enough. Thick ground wire from gearbox to left motor mount
Edit: Is the ground wire from the gearbox going to the starter!? If so...do not do that! Place it somewhere attached to the left motor mount.
Third pic, ringed end goes from same spot on gearbox as second pic across to left chassis rail.
mr2magic wrote:First pic isn't ground, it's battery positive.
perfect thanks, yes just twigged my error putting the earth on the same as the positive from the battery for the starter oops. glad i hadnt hooked the battery up :S
Ok, ill sort these out when i get home.
big ring should go on one of the top 2 gearbox bolts, other end to chassis.
Do not ground the starter from that point! that is the 12v, it's grounded through the gearbox. that's how you fry wiring
Just think that the gearbox, block and head all want to be grounded to the chassis. that's it really, more decent connections from the block, box and head to the chassis, the better.
Try to find points on the chassis that are a direct bolt in, rather than via a bracket etc. Just makes a better quality ground.
post back up the finished pictures before hooking up the battery. just in case
pbmr2 wrote:big ring should go on one of the top 2 gearbox bolts, other end to chassis.
will do, attempted to get photos last night but it was too dark and the flash wasnt very helpful on the camera.
ive removed the ground off the starter
You certainly wouldn't be the first person to make that mistake with the ground / starter. At least you didn't have a battery connected / try to start it!
Gazza_DJ wrote:You certainly wouldn't be the first person to make that mistake with the ground / starter. At least you didn't have a battery connected / try to start it!
It felt like that's where the wiring wanted to sit naturally. I did think why would I connect the battery terminal to the starter too.
Forgot to say. Looking at the front of the car. Positive battery terminal is on the right yes? Passenger side?
Positive is the one that doesn't go directly to the chassis. Can't remember which way round they are!
Can't look now but i'm sure my positve terminal is on the drivers side.
If in doubt take the battery/frunk liner out and follow the cable back as far as you can and you will find the negative bolted to the body.
abovetherim wrote:Can't look now but i'm sure my positve terminal is on the drivers side.
will take a look later thanks guys!
