rev4 n/a to rev3 turbo conversion
Post new topic   Reply to topic       www.imoc.co.uk Forum Index -> Member Profiles -> Project Cars
Author Message
paul_4xxxx
Guest
PostPosted: Thu Apr 17, 2008 3:28 pm    Post subject: rev4 n/a to rev3 turbo conversion Reply with quote Reply with quote including images
been thinking of doing this for the last 2 years and now im well on the way..
i just purchased a rev3 rear clip so i have began stripping my car down to make way for the new power plant
pictures to follow...
firstly i removes both rear wishbones, then exhaust
then i went on to the boot. i removed the ecu and all wiring to the rear lights and fed the loom through into the engine compartment
then into the passenger compartment. i pulled the drivers seat out, glove box between the seats and the center console, then removed the gear cables and fed them through to the engine compartment.
next up was the wiring loom to the passenger footwell, i unpluged all the connectors and started pulling the tape off the wires, there are 2 thick wires that need to stay... i worked my way back seperating these 2 wires from all the others and undone all the connectors all the way to the rear bulkhead...
i have sold the gearbox and exhaust, so they have now gone, so my engine is now resting on a 2"/4" plank of wood... i will be buying an engine hoist and cradle in the next week or so... then i will be able to remove the engine completely and give the engine bay a good clean...
then i need to buy a turbo fuel pump and get that plumbed in...
will update in a day or so...
Back to top
paul_4xxxx
Guest
PostPosted: Sat Apr 19, 2008 2:44 pm    Post subject: Reply with quote Reply with quote including images
how the car looks now
gearbox is out... and sold...
disconnected the loom at the drivers footwell and seperated from the 2 thick wires...
and fed the rest of the loom through the rear bulkhead
now its resting on the top of the engine
the next job was the gear selector cables, these come out really easy
and now im left off with a pile of junk...
Back to top
Century Motorsport
IMOC Affiliated Trader
PostPosted: Sat Apr 19, 2008 6:30 pm    Post subject: Reply with quote Reply with quote including images
Are the pics taken in a tropical country?!?!
Sure doesnt look like anglesey weather!
Good work, its a decent sized task but be patient and im sure you'll have fun doing it.
Nathan
_________________
Builders of the the UK's first 9second MR2 - 9.722 @ 148 MPH ----- 07947883103 ---- www.centurymotorsport.com
Back to top
User is offline
paul_4xxxx
Guest
PostPosted: Sat Apr 19, 2008 7:21 pm    Post subject: Reply with quote Reply with quote including images
lol... was acctualy sunny yesterday wen i took them... pleanty more pics to follow in the new few weeks...
if anyone notices me doing anything wrong, just tell me... i am a beginer...
well... i have done engine changes b4, but not on mr2s
Back to top
paul_4xxxx
Guest
PostPosted: Thu Apr 24, 2008 12:36 pm    Post subject: Reply with quote Reply with quote including images
been doing a bit more today..
cleaned and painted my new calipers and carriers
fitted my new quick shift i bought off ebay. no pics tho... i forgot to take them
and got some new toys this morning
Back to top
paul_4xxxx
Guest
PostPosted: Wed Jun 11, 2008 3:13 pm    Post subject: Reply with quote Reply with quote including images
right... payed for my engine today so it will be in and running in the next few weeks... i only got 2 days a week i can work on it, but that shudnt be a problem...
im gonna polish every part i can to save time and when i can afford it, they will be powder coated green to go with the rest of my colour scheme...
i need to fit manifold and downpipe before the engine goes in aswell... then i need to fit exhaust system...also... i wanna buy an xs power intercooler with shroud and spal fan... and i have bought a turbo engine lid so im gonna buy a rogue fan kit...
then i need to buy hks ssqv dump valve and an apexi boost controler...
Back to top
paul_4xxxx
Guest
PostPosted: Wed Jun 11, 2008 3:21 pm    Post subject: Reply with quote Reply with quote including images
got quite a bit done today ready for the the arrival of my new engine
removed the engine bay fan from the drivers side,
removed a load of coolant hose and the ignitor from the engine bay,
fitted my new turbo engine lid
removed the fuel tank... but had a problem...
i rounded this union off while trying to undo it, so.... i had to cut the pipe
i am going to cut the fuel pipe on both sides of that union on the hard pipe part and repair it with some fuel hose double clipped on each end with some jubilee clips..
hopefully it will hold pressure, if not, i will have to get a new pipe from toyota..
heres the tank out
more to come when my engine gets here
Back to top
paul_4xxxx
Guest
PostPosted: Thu Jun 19, 2008 4:52 pm    Post subject: Reply with quote Reply with quote including images
got my engine on tuesday, 1 day early... cheers larry93 [thumleft] your a top man!
and there it is... now... on with the fitting.
done ecu and intercooler first..
then i hired an engine hoist.. only 15 [Very Happy]
i lifted the car up with it first, to give me enough room to get the engine in underneath, then i put the engine on my crawler and rolled it under into the engine bay,
then i lowered the car over the engine, and lifted the engine into place..
FITTED [Cool]
i only managed to hook up half the electrics and half the fuel system and coolant system before it started to rain [Sad] i was hoping to have it fired up by tonight, but never mind... will do that next week
Back to top
paul_4xxxx
Guest
PostPosted: Sun Jun 22, 2008 11:27 am    Post subject: Reply with quote Reply with quote including images
got the engine turning over yesterday, just gotta fill it up with fuel and fit the fuel feed pipe, then i can start it up [Very Happy]
Back to top
paul_4xxxx
Guest
PostPosted: Fri Jul 04, 2008 12:45 pm    Post subject: Reply with quote Reply with quote including images
got the engie running yesterday [Very Happy] wnt be long until its on the road and i will put a video up on youtube
Back to top
paul_4xxxx
Guest
PostPosted: Thu Jul 17, 2008 12:56 am    Post subject: Reply with quote Reply with quote including images
bought some new bits..
motoria exhaust which i will be getting delivered on friday,
downpipe to be delivered friday
"3sgte inside" stickers off the bay.
im getting my hubs, shafts and discs on friday aswell.
next on my shopping list is 2 rota torque drift in 17x9 to go on the rear.
CRN discs and yellow stuff pads
viper cat1 alarm with remote start
blitz boost controler
MOT
tax
and insurance...
hopefully it will all be done before JAE
Back to top
StuRobinson88
PostPosted: Sun Jul 20, 2008 8:38 am    Post subject: . Reply with quote Reply with quote including images
looking very very good!
i was going to do something similar as i had a fair whack saved up when i bought my 2, but then i spunked it all on bits and pieces. i don't think i could afford the fuel bills anymore anyway, lol.
keep up the hard work, and get some more pics posted, he he.
Back to top
User is offline
paul_4xxxx
Guest
PostPosted: Sun Jul 20, 2008 11:25 am    Post subject: Reply with quote Reply with quote including images
not going to be back on the road before JAE i dont think... got my shafts and hubs yesterday but the wires for the abs sensors were cut, and i didnt get me rear suspension arms...
so there next on my shopping list.
got the motoria exhaust fitted on friday. the car sounds well meaty with that on.
still lots of work to do. and im gonna be getting a viper 500xv alarm fitted aswell
Back to top
Display posts from previous:
Post new topic   Reply to topic       www.imoc.co.uk Forum Index -> Member Profiles -> Project Cars All times are GMT
Page 1 of 1
Jump to:
