Does anyone know the model Year of the MR2 Turbo which has Clear Side Lights as standard? Mine is a MR2 Turbo Rev 3
Many Thanks
Karen
Clear Side Lights
Re: Clear Side Lights
Rev 4 and 5 cars had clear sidelights as standard.
cheers steve but the jdm turbo has the dif. side repeaters that sit on the bumper does anybody have the toyota part no. for the clear side lights on the later spec turbo's? it's just that i've had a prang that obviously needs to get repaired through the insurance company, (i had clear after market ones fitted) but i don't want the standard hideous orange things that come standard on my car! so, if anybody knows the part no. or the details of a later spec car? (apparently, toyota need to know the chassis no. ect) i would greatly appreciate it! thanks for all you'r help
Clear sidelights and side indicators
karen hazlewood wrote:cheers steve but the jdm turbo has the dif. side repeaters that sit on the bumper does anybody have the toyota part no. for the clear side lights on the later spec turbo's? it's just that i've had a prang that obviously needs to get repaired through the insurance company, (i had clear after market ones fitted) but i don't want the standard hideous orange things that come standard on my car! so, if anybody knows the part no. or the details of a later spec car? (apparently, toyota need to know the chassis no. ect) i would greatly appreciate it! thanks for all you'r help
Hi Karen.
Stef is correct in that as of the Revision 4 (1996-ish) the fronts of MkII's were kitted with clear lens units to help modernise the look. This is the answer you were looking for as your original post was about sidelights and not the side repeaters. What you need is;
81521-17090 Lens & body Front right
81511-17090 Lens & body Front left
81620-17020 Left Hand Side Cover assembly
81610-17020 Right Hand Side Cover assembly
2x Amber bulbs (from Halfords)
Your local Toyota parts chap should be able to order the correct parts with you a) supplying your own VIN details and b) performing his/her own search to make sure the right parts are ordered.
Should you also want to upgrade to the clear side repeaters, the part number is 81731-20220 (again, check first!) but this will involve some drilling/cutting of the side wings and removing/blanking the std wedge ones.
Regards,
Jonty.
Re: Clear sidelights and side indicators
The last couple of times I've purchased these parts from Toyota, contrary to popular belief the two amber bulbs have been included.
They're situated in the bulb holder ready for use.
