Hi,
I have found some alloys that I would like to fit to my Rev 1, but I would like to run the size by the gurus on the site before I willy it up....
Front - 17inch 7.5 wide, 215.40.17 offset 35
Rear - 17inch 7.5 wide, 235.40.17 offset 35
It is the offset that I was not sure about...will these fit OK or will I need any spacers or anything?
Thanks a lot for any advice....
They are ROTA Battle alloys by the way.
A quick check on offset
Re: A quick check on offset
Hi Billy, They'll fit
Running the same width's & offset on mine. On rare occasions (very bad dip in road) the fronts do scrub against the plastic arch lining, But it is lowered 50mm
Hi Andy,
Thanks very much for the reply.
That means I can order them with peace of mind.
Appreciate that a lot!
Regards
Billy
Regards
Billy
