anyone know what size the gen 3 rx7 (92-99) injectors are? are they 850cc or more like 550cc?
They've got two injectors per inlet port. Try asking Si Cook on the IMOC-UK YahooGroups List - he's got a 1995 R (s?) model.
gen 3 rx7 injector size
Re: gen 3 rx7 injector size
screech wrote:anyone know what size the gen 3 rx7 (92-99) injectors are? are they 850cc or more like 550cc?
I believe the secondary rx7 injectors are 850's side feed. This is what I am running in mine.
paul
Yup Paul is right, could be a decent and cheap source of injectors but trying to find used ones kicking around is nigh on impossible without some serious hawking.
James
James
problem is you can only get them in sets of 3 second hand as thats all they had i think.
There hard to come by.
i read about suppliers having to order 12 at a time to make up 3 sets. This is 4 sets of rx7 injectors tho.
2x 550's, 2x850's
The reason for the packaging maybe down to the jap market with many having triple rotors in them !
Brilliant engine, so small yet so powerful, but very thirsty about it too and designed to use oil !
People whom often upgrade, keep their 850's for the primary injectors and start using 1200cc's for their secondary supply.
what dustbin turbo is pete fitting to his then?
Is he doing the whole lot or just a turbo injectors and ecu?
lee
lee
thelegend wrote:what dustbin turbo is pete fitting to his then?
lee
Hes doing the whole lot ! I think the injectors he gone for are 1600cc !
The turbo he's gone for is 0.70 a/r on the compressor, its all external gate, manifolds, large FMIC, suspension ... again... damn, if you saw the way it shifted before at only running 11 psi !! lol !! it was fantastically quick !
What sort of injectors are interchangable with the MR2? I was looking at some nice impreza ones which i was told would fit?
