I promised to show pictures of my central locking fix - here they are.
The problem was as follows: When I used the driver's side key, both doors were locking ok, but the passenger's door would not unlock.
Remove the passenger lock -
Inside the lock there are two small rubber bushes -
One of the bushes had split and this allowed the mechanism to travel beyond the electrical contacts. (you can see my old temp repair using a bit of cable insulation - didn't last long )
Replaced the bush with a piece of rubber cut from a pencil eraser !
Jobs a good un. I hope this helps someone.
Oscar
Central Locking Fix
- Lauren
- IMOC Committee
Re: Central Locking Fix
Good stuff!
