Hi all
New MR2 Owner here, I'm after the Haynes manual. Unfortunately this is out of print and not available as PDF.
There are zero available on ebay and other sites.
Is anyone selling or would be able to scan a copy? I'm getting quite desperate at this point.
Thanks in advance
Mike
Haynes Manual
- IMOC Moderator
Re: Haynes Manual
Hi there welcome
Google BGB (Big Green Book) MR2 MK1
Loads out there and or post any problems or request for anything specific on here memebrs will be only too pleased to help
try here you even have a choice http://manual.teq.org/
regards Brian
regards Brian
- IMOC Moderator
Re: Haynes Manual
also here
the manuals will be us and elsewhere specific but in general this is what we all refer to
http://western.net.nz/wheels/mr2/mr2.htm
Re: Haynes Manual
Cancelled
- IMOC Moderator
Re: Haynes Manual
same as in the tech org link i forgot aboout marks links some are dead but basically all the links have the same info
but thanks for posting to assist a new member
Regards Brian
Re: Haynes Manual
All the MK1 BGB stuff is available here https://www.mr2oc.co.uk/download-cats/c ... 0-mk1.html
- IMOC Moderator
Re: Haynes Manual
jimi wrote:All the MK1 BGB stuff is available here https://www.mr2oc.co.uk/download-cats/c ... 0-mk1.html
Hi Jimmy
I knew youd be along at some point cheers
regards Brian
Re: Haynes Manual
How's tricks Brian ?
He posted on the OC as well, I did tell him he would be far better off with the BGB's rather than the Haynes book of lies
Jimi
Jimi
- IMOC Moderator
Re: Haynes Manual
Hi Jim
Just trying to keep the company going me & the rest of the board & management team, are having sleepless nights over it all, if lockdown doesnt lift for the hospitality side of the business (biggest part) we will be locking the doors & throwing away the keys.
But we have to remain positive !!!
Take care fella
Take care fella
Re: Haynes Manual
Looks like a good site to get Toyota manuals. Thanks
Re: Haynes Manual
Be aware that if you download the pdf in the link to shinny's storage, that the ecu diagnostic codes in it are not correct for a UK MK1 and all the parts referring to cats and EGR systems do not apply to UK spec cars.
If you use the link I posted you can download the 4A-GE engine manual ( which has the correct codes) and the correct electrical diagrams for a UK spec car
Re: Haynes Manual
jimi wrote:Be aware that if you download the pdf in the link to shinny's storage, that the ecu diagnostic codes in it are not correct for a UK MK1 and all the parts referring to cats and EGR systems do not apply to UK spec cars.
Thank you for the tip, jimi!
