Just bought a Shed! * Pictures added!*
Re: Just bought a Shed! * Pictures added!*
My 96 doesn't have abs.![](./images/smilies/spacer.gif)
My MR2 for sale! Check out the for sale section
Rory wrote:My 96 doesn't have abs.
Thanks, that's good to know!
chooch wrote:Should my car have ABS or not? It's a 96 UK car as above, there is no light on the dash and the wheels lock up when you hit the brakes! I just thought a car of this age would have it..
You'll be able to tell if it has ABS by looking under the bonnet.
could be a late rev3.
Both my rev4 cars have abs, but one of them has cloth seats.
Unless you want to get welding and want a big project, then it's not worth saving sadly
That MOT history is great!
Love the comment about it being a sixteen year old car blah blah.
Obviously a friendly tester as it always failed emissions.
then passed.
then failed.
then passed.
haha
That's a rev4 engine, can see the EGR setup.![](./images/smilies/spacer.gif)
pbmr2 wrote:That's a rev4 engine, can see the EGR setup.
That's great thanks! Maybe I should invest in an EGR blanking plate, to free up some ponies and eliminate any potential issues.
I got a shot under the bonnet, am I right thinking that this is an ABS pump?
![Image](https://i.imgur.com/PWKzfFV.jpg)
cheers,
Ewan
Yes, that is an ABS pump
Blue Lexus RCF
Black MKIV UK Manual Supra
Green MK2 MR2 Tin Top
So after driving the car in the rain and parking it out in the rain, it wouldn't start last week.
Thankfully I managed to get it started at weekend and have it inside now.![](./images/smilies/spacer.gif)
upon inspection I found the boot flooded.![](./images/smilies/spacer.gif)
![Image](https://i.imgur.com/tsEzr5a.jpg)
I can only guess that it has been coming from the wheel arch where there is a much bigger gaping hole than expected!
![Image](https://i.imgur.com/uGzwwbU.jpg)
Could this have played havoc with the ECU? it seemed dry.
Possibly, due to moisture getting inside it.
That's a big hole!!
![Surprised :o](./images/smilies/icon_surprised.gif)
That is a lot of fails.
it failed pretty much every year.
Good luck sorting it.![](./images/smilies/spacer.gif)
Normally the coil gets cracks in it and then water finds it's way in.
would be my first guess.![](./images/smilies/spacer.gif)
Draven wrote:That is a lot of fails.it failed pretty much every year.
No plans to sort it, current plan is to drive until MOT expires, then break for spares, hopefully gather enough funds to cover expense of car and maybe buy another.
pbmr2 wrote:Normally the coil gets cracks in it and then water finds it's way in.would be my first guess.
Thanks, coil was fine, think it was condensation upsetting the ECU or something else.
Well I took it out in the snow and managed to survive! It developed a fault with the steering
(possibly due to the cold) and wanted to go sideways on the straights! So I took the car to my local garage and the steering rack is fubar! It's as if the rack and pinion are skipping.
However surprisingly they said the car is fairly solid and would only take a couple hours welding to fix the wheel wells ![Shocked :shock:](./images/smilies/icon_eek.gif)
Welcome along.
Get a second opinion before you plough a load of cash into it.
hojoos wrote:Welcome along..
Hi, well it made it through another MOT in August, got a few wee jobs to do before spring.
Well I managed to get it through another MOT in December! Shame I got the car back without powersteering.
It appeared to fail when I collected the car and it isn't the relay! So currently driving it with out the power steering ECU and building up my upper body!
Ewan
Ewan
good job keeping it on the road ![thumleft :thumleft:](./images/smilies/icon_thumleft.gif)
