Hi all,
My 1990 Rev1 turbo failed its MOT because the high beam indicator light isn't activating.
The actual high beams and flash all work fine.
I thought it would just be a bulb replacement, but unfortunately it wasn't that easy.
I checked the voltages on the indicator bulb contacts and when lights are off it measures 0v, when dipped headlights are on it shows 0.3v and when high beams or flash are activated it goes up to about 1.3v, though if I hold the flash the voltage creeps up slowly up to 2v or just above.
I tested the voltage on the high beam pin on the connector to the dash and traced it to the connector under the steering column and verified those are also seeing the 1.3-2v
I've cleaned up the ground in the driver footwell are but no difference.
Checked voltages on the right hand headlight bulb connector and it seems ok, about 12v on the 2 live wires on dipped and then the voltage reduces on one of the live wires when high beams are activated so that seems ok too.
Someone suggested it could be dodgy contacts in the headlight switch.
Is this what the end of the headlight stalk connects to? And to get it out do I need to remove the steering boss, etc.
to pull the assembly off?
Any help or suggestions would be very much appreciated.
Rev1 Tubby, Garrett GT3071R, Motec M4 EMS, 880cc delphis, Rev3 turbo port polished built head/cams/titanium retainers, shim under buckets, HD springs, etc.
, rear bumper mounted intercooler, and vanilla air freshener.
