Wonder have I a head gasket issue.
Here's the story.
MR2 MK1A is only used for car shows
& vintage runs.
When I return from a run the engine has pushed out about 2 inches of coolant into the expansion bottle.
But when it cools down it only takes back about half an inch of coolant to the engine.
Normally I just syphon out the coolant from the bottle the following day
& pour back into the filler neck
& repeat after every run.
Compression is perfect in each cylinder
& radiator, thermostat, filler cap
& expansion cap have been replaced.
Coolant has been bled correctly
& idle is perfect
& no sound of air in the pipes.
I got my mechanic to detect any exhaust gasses in the coolant using his kit
& nothing detected.
Pressure must be getting into the cooling system.
Not sure why the coolant isn't being pulled back into the engine.
New cap is
.9bar.
Did a 60 mile run last Sat in quite hot weather
& extra coolant was pushed out to expansion bottle
& a little taken back.
I found this time that I couldn't return the same amount of coolant to the filler neck so I'm guessing that there must now be some air in the system.
I have a mark on the expansion bottle just above half way so I know what my starting point is.
Anyone got any ideas?.
Might be a head gasket job over the winter.
Thanks,
Tim
