Interior water leak
simpson_eh
Interior water leak
Post by simpson_eh »
Hey all
Trying to trace a water leak in my tintop 2,. Stripped the interior to sound deaden and noticed water leak on floor,. It's coming from the the wiring in the passenger footwell but not from the door or seal
Any ideas
Have photos but don't know who to use to link them in
If you see an MR2 with a raised engine cover, the bottom line is it's probably faster than your car.
rev2rich
Re: Interior water leak
Post by rev2rich »
From the scuttle panel area.... Get some food colouring a bright colour mix with water and test areas that helped me to find the problem :-k
Hope it helps Rich
Al-sw20
Post by Al-sw20 »
Heater core.
simpson_eh
http://i990.photobucket.com/albums/af23 ... ddtd6s.jpg
def not the doors just right under the wire
Rob
Post by Rob »
probably sill drains blocked. Poke a thin flat blade up the seam pinch drain of the sill and i bet loads of water comes out.
