knock sensor
autobody
knock sensor
Post by autobody »
Question for the SC owners - is there any other knock sensor that will work with the 4agze?
I am getting a error code 52 and I am unable to find a replacement, I have contacted Toyota and been told its discontinued, this is the part number I have 89615-17010.
I think it may be a case of holding out for a used one but I would be interested to know what others have done.
p.s. if you do have a spare knock sensor I will be happy to buy it. :thumleft:
kaiowas
Re: knock sensor
Post by kaiowas »
TCB sell various knock sensors for Toyotas, I'm pretty sure one of them will be the right one although none of them are listed for the 4A-GZE
Think it might be the QIC 916 although it's probably best to give them a call and check rather than ordering one blindly.
autobody
Re: knock sensor
Post by autobody »
Thanks, just given tcb a call and are currently checking if it fits.
autobody
Re: knock sensor
Post by autobody »
TCB have said the QIC 916 knock sensor will not work as it has different frequency readings. They don't stock 4agze knock sensors.
But I have now got a second hand unit. (Hope it works) I am going to temp to fit this in on Sunday.
Can I ask if other have done this job what was required? Is it accessable under the car? Do I need to remove any items to get to the knock sensor. Any tips appreciated. :thumleft:
kaiowas
Re: knock sensor
Post by kaiowas »
From memory it should be easy enough and accessible from underneath without removing anything although some contortion may be required, you should certainly be able to get the socket on, I just can remember how easy it is to find enough space to swing a ratchet. Oh and make sure you have a deep socket of the appropriate size, a standard socket won't cut it.
Also take care with the wiring/connector when unplugging the old one. Not sure if I've just been unlucky but all the GZE looms I've had have been particularly fragile in this area.
autobody
Re: knock sensor
Post by autobody »
Update: replacment knock sensor fitted and looks to have done the trick. I have a small coolent leak at the front so only took the car behind my house. Drives much much better and no engine light.
To confirm, 27mm deep socket used and a small extension. Found I had just about enough room.
Thanks for your help kaiowas :thumleft:
autobody
Re: knock sensor
Post by autobody »
Here is a pic of the knock sensor.
Both had Toyota markings on them. The top one came off the car and the bottom one was a replacement. Look similar but the bottom one was longer slightly.
jayelem
Re: knock sensor
Post by jayelem »
could do with one myself!
jon_st205
Re: knock sensor
Post by jon_st205 »
Let me dig around, I'm sure I have one somewhere.
jayelem
Re: knock sensor
Post by jayelem »
ive even crossed my balls in hope!
jayelem
Re: knock sensor
Post by jayelem »
Bank holiday bump!
SuperRedMR2
Re: knock sensor
Post by SuperRedMR2 »
Has anyone else got a spare?
SuperRedMR2
Re: knock sensor
I bought a GZE knock sensor second hand in the end. My mate who is also has a genuine white over silver JDM GZE aw11 had two spares as well. Not cheap.
