I have a head I wanted to use but discovered some very deep scores when I removed the cams which were also well ruined, now I have spare caps and new cams do we think I can flat out the scores and use the head?
Please only reply if you have experience no speculators...
Scored cam seats
Re: Scored cam seats
You cant use different cam caps to those that were produced with the cylinder head.
The head/caps are bored as 1 and so are unique.
time to buy a complete cylinder head
Agreed, in gonna try anyway
Plan is to sinch up caps lightly, and check fit, loose no good tight I will lap the components together, try it and inspect after running for a few hours ....
Not the way to do it but good luck. At the very least plasti gauge it all.
