View previous topic :: View next topic |
Author |
Message |
Rosssco
Joined: 05 Nov 2005 Posts: 908 Location: Aberdeen Feedback Score: 30
Posted: Wed Sep 27, 2017 4:38 pm Post subject: |
What ECU are you using Paul?
I ask as I seen this while browsing for something else:
https://www.scs-delta.co.uk/product-page/lotus-evora
Not cheap granted, but then for an (almost) PnP harness with a base calibration, and spec, its pretty interesting for the 2GR posse..
Back to top |
gavsdavs
Joined: 15 Nov 2012 Posts: 652 Location: saahfeeeeastlaandun Feedback Score: 2
1991 Toyota MR2 Mk2 NA Rev2
Posted: Wed Sep 27, 2017 9:15 pm Post subject: |
Rosssco wrote: | What ECU are you using Paul?
Not cheap granted, but then for an (almost) PnP harness with a base calibration, and spec, its pretty interesting for the 2GR posse.. |
Interesting - I might strike up a conversation with them for testimonials.
Back to top |
PW@Woodsport IMOC Affiliated Company
Joined: 14 Dec 2004 Posts: 7601 Location: durham Feedback Score: 30
Posted: Thu Sep 28, 2017 5:54 am Post subject: |
Interesting indeed, although with the stock Lotus ECU being mappable I wonder what the point is?
It's one of the reasons I went for full Lotus Evora ECU/loom etc
_________________
Back to top |
monkeyra Premium Member
Joined: 03 Apr 2006 Posts: 1158 Location: Hertfordshire Feedback Score: 13
1990 Toyota MR2 Mk2 V6
Posted: Fri Sep 29, 2017 1:44 pm Post subject: |
gavsdavs wrote: | Rosssco wrote: | What ECU are you using Paul?
Interesting - I might strike up a conversation with them for testimonials. |
Let us know if you do.
_________________ SW20 Rev1 Supercharged 2GR-FE Powered Trackday Car.
Back to top |
Rosssco
Posted: Mon Oct 02, 2017 2:57 pm Post subject: |
PW@Woodsport wrote: | Interesting indeed, although with the stock Lotus ECU being mappable I wonder what the point is?
It's one of the reasons I went for full Lotus Evora ECU/loom etc |
I presume if you want an open source ECU with all the additional feature it offers.. Variable slip traction control and launch control would be particularly handy features which can't currently be integrated with the standard Evora ECU IIRC.
Plus there are limited places that can calibrate the Lotus ECU (and is it completely open, or restricted to just modifying tables etc.?), where as an additional modifications can be implemented anywhere and mapped by essentially anyone.
https://s3.amazonaws.com/wix-anyfile/TKMXGJq1Tq6RNDJuzywQ_Delta%20800.pdf
Back to top |
Posted: Tue Oct 03, 2017 6:31 am Post subject: |
Fair points, I just guessed most people would only want the ability to tweak the maps, including me, which the stock ECU offers.
Looks like a good option for those that want more than that I suppose.
I'm a big fan of factory tunes, big manufacturers spend millions getting it right, rarely do I see a car running on a standalone that cold starts well, idles perfectly or doesn't have the need for constant tinkering, plus you're very much at the mercy of the tuner.
Of course I can never go standalone anyway due to my Evora Canbus network communicating with the dash, the ABS module and the TPMS.
Looks great for those that want to go crazy though.
Back to top |
Rosssco
Posted: Tue Oct 03, 2017 11:47 am Post subject: |
Paul,
Yep, if you're happy with the OEM calibration level, and don't need the additional functionality (e.g. traction control is probably on a big deal if you drive a lot in poor / variable road conditions) then its an unnecessary expense..
On the calibration, I guess it really depends on how much time / effort has been put into the development side. as there's no reason you cannot get OEM levels of drivability and day-to-day use from modern non-OEM ECU's. I was working on the basis that the 'base' map was suitable for a standard Evora.
And yep, you could use this ECU as it has CAN-Bus operation (according to the spec) so will operate all dash and ancillary functions - I presume they are offering it to Evora owners will want to retain all the existing functionality of their cars (not sure if it retains the standard stability systems, not applicable to MR2's anyway!) rather than aimed squarely at the race car market - part of the reason this one piqued my interest was the offering of road car integration.
Anyway, yep its another option for someone potentially!
Back to top |
Posted: Mon Oct 30, 2017 9:14 pm Post subject: |
So it's been 6 months since I worked on my super widebody Evora S spec project, so decided to blow the cobwebs off it and get it outside for a walk around view of how it looks so far. It's the first time we've been able to study the lines from a distance. I think we're pretty much happy once the wing edges are rounded off.
Back to top |
Marty J
Posted: Mon Oct 30, 2017 10:24 pm Post subject: |
I like the look of the rear with the diffuser, is it for looks or function ?
What's the ground clearance at the front?
Back to top |
Posted: Tue Oct 31, 2017 7:39 am Post subject: |
No idea on the diffuser to be honest, without wind tunnel testing it would be hard to say if its adding any functionality, I just think it finishes off the bland area of the TRD bumper really well, believe it or not it's from a Clio but fits almost perfectly.
Front bumper looks a bit high to me, I will be adding some sort of carbon splitter to rectify that.
Back to top |
MRV6 Premium Member
Joined: 14 Dec 2004 Posts: 973 Location: North East of England Feedback Score: 8
1994 Toyota MR2 Mk2 V6
Posted: Tue Oct 31, 2017 8:07 pm Post subject: |
[quote="PW@Woodsport"]So it's been 6 months since I worked on my super widebody Evora S spec project, so decided to blow the cobwebs off it and get it outside for a walk around view of how it looks so far. It's the first time we've been able to study the lines from a distance. I think we're pretty much happy once the wing edges are rounded off.
That's the money shot for me mate, that back end is nearly as wide as yours.
Back to top |
Posted: Wed Nov 01, 2017 6:54 am Post subject: |
I styled the rear on your wallet, super fat and never been seen before.
Back to top |
Draven
Joined: 10 Feb 2006 Posts: 14818 Location: One of the Hamptons. Feedback Score: 43
Posted: Wed Nov 01, 2017 1:14 pm Post subject: |
That looks pretty special, so nearly finished then?
Back to top |
Posted: Wed Nov 01, 2017 2:20 pm Post subject: |
God no, there's months of part time work left in it, she will get there eventually though.
Back to top |
danthevanman
Posted: Wed Nov 01, 2017 4:36 pm Post subject: |
Looks really nice
It's a credit to your skills and knowledge.
I hope I can use your skills on my 2 in the coming years.
Back to top |
MRV6 Premium Member
Posted: Wed Nov 01, 2017 7:29 pm Post subject: |
PW@Woodsport wrote: | I styled the rear on your wallet, super fat and never been seen before. |
Hmm interesting when you have never seen it!
You need to get the doors on son and all in one colour so we can get a better perspective on it.
Back to top |
