Retracting Wing Mirror Kit
Parts for the Mk2 MR2 only (excluding bodywork and wheels/tyres)
Chumbaside
Post by Chumbaside »
In an effort to reduce weight in my track MR2, I've removed the retracting setup from the car.
"Kit" includes both door looms, retract relay and motors for each wing mirror as well as the door switch panel. Simply remove your standard motors, fit the retracting setup, swap out door looms and add the relay (all JDM MR2's have the wiring for this apparently). I've even popped the pins out of the connectors to make it really easy to fit in your mirror casings!
Door switch panel tab has been repaired - see photo.
£165. Ideally collected from Sutton Coldfield but will post at buyers expense.
Return to “Mk2”
