[Mk2] [NA] Where to start?
Goto page Previous  1, 2
Post new topic   Reply to topic       www.imoc.co.uk Forum Index -> MR2 MK2 1990 - 1999 NA & Turbo -> Mechanical
Author Message
pbmr2
Premium Member
PostPosted: Mon Jul 31, 2017 5:04 pm    Post subject: Reply with quote Reply with quote including images
Did you crack this issue?
I'm not 100% on the rev1/2 changes to the idle valve. best ask someone who's worked on both and remembers. been about 7 years for rev2 and 10 years for a rev1 for me. The memory isn't what it was [Very Happy]
Back to top
User is online now
Rhyswh
PostPosted: Thu Aug 03, 2017 1:01 pm    Post subject: Reply with quote Reply with quote including images
Not yet. We ordered the part but it came in worse condition than the one we have!
We cleaned the ISCV we have and it's very free moving apart from the very last bit. So it will fully open but won't fully close without using some force. Without the sensor attached I can manually close the ISCV and make the car idle properly so pretty sure this is the part is causing the issue. Tested the sensor attached to it and it did nothing! So replaced that as well but worried that it's bust because like I said, it came in worse condition than the one already on the car.
So at the moment we're no further forward until we get another part, the seller said he would send us another but all of a sudden he's gone quiet [Sad]
Back to top
User is offline
mr2garageswindon
1994 Toyota MR2 Mk2 NA Rev3
PostPosted: Fri Aug 18, 2017 2:43 pm    Post subject: Reply with quote Reply with quote including images
Check your cam timing. I bet its a tooth out hence low on power.
Back to top
User is offline
Rhyswh
PostPosted: Tue Aug 22, 2017 10:20 am    Post subject: Reply with quote Reply with quote including images
If it's a tooth out is it just a case of resetting the timing to 10deg?
Back to top
User is offline
Rhyswh
PostPosted: Tue Aug 22, 2017 12:06 pm    Post subject: Reply with quote Reply with quote including images
Scrap that! Was thinking of the wrong thing, although I will check the ignition timing as well.
How easy is it adjust the cam timing if it's out on these cars?
Back to top
User is offline
Rhyswh
PostPosted: Mon Sep 04, 2017 7:58 am    Post subject: Reply with quote Reply with quote including images
Finally got his money back, new part ordered!
Back to top
User is offline
pbmr2
Premium Member
PostPosted: Mon Sep 04, 2017 7:35 pm    Post subject: Reply with quote Reply with quote including images
Easy once you get the cover off.
just cut a slice of a 2L or 3L coke bottle, longer than the contact patch of the belt to cog. feed the plastic under the belt as the engine turns by hand. once the plastic is between the belt and the cam gear, the cam gear can be turned to reposition it.
quick time saving trick for sorting out a small mistake.
Back to top
User is online now
Rhyswh
PostPosted: Thu Sep 07, 2017 8:48 am    Post subject: Reply with quote Reply with quote including images
Brilliant tip there!
Got the new part on yesterday. I was hoping the car would stall as the idle control screw is as low as it will go. It didn't but was idling a lot better at 1000rpm. This is still a touch high though and I can't adjust it any lower.
Anything else I should check with regards to idle?
Back to top
User is offline
Display posts from previous:
Post new topic   Reply to topic       www.imoc.co.uk Forum Index -> MR2 MK2 1990 - 1999 NA & Turbo -> Mechanical All times are GMT
Page 2 of 2
Jump to:
