[Mk2] [Turbo] Turbo Flutter - with video
Post new topic   Reply to topic       www.imoc.co.uk Forum Index -> MR2 MK2 1990 - 1999 NA & Turbo -> Mechanical
Author Message
killerferret666
Premium Member
PostPosted: Mon Aug 21, 2017 9:51 am    Post subject: [Mk2] [Turbo] Turbo Flutter - with video Reply with quote Reply with quote including images
So ive installed a rev2 forged build with a rev3 conversion running a CT20b. I have a BOV installed which is an aftermarket one to atmosphere.
Ive noticed at lower boost / part throttle I get turbo flutter and then at WOT or high boost the BOV does sound.
The below video demonstrates. Is this anything for me to worry about or anything I need to look at. Obviously it sounds cool but apart from that is it an issue?
https://www.youtube.com/watch?v=LmlFtUYPm2U
_________________
My Blog on Miami GT4 kit car build using MR2 Donor Car
http://miamigt4kitcar.blogspot.co.uk/
twitter for photo's as I'm building -
www.twitter.com/iwanabeaferret
Back to top
User is offline
Gazza_DJ
Premium Member
1997 Toyota MR2 Mk2 NA Rev4
PostPosted: Mon Aug 21, 2017 10:24 am    Post subject: Reply with quote Reply with quote including images
I don't think it's a problem.
Back to top
User is offline
killerferret666
Premium Member
PostPosted: Mon Aug 21, 2017 9:14 pm    Post subject: Reply with quote Reply with quote including images
Ok cool. Ill see how it behaves generally.
Back to top
User is offline
androo007
Premium Member
PostPosted: Mon Aug 21, 2017 9:27 pm    Post subject: Reply with quote Reply with quote including images
Have you got an arc airbox or similar? Made my flutter sound louder. It's not a problem [thumleft]
I run with no bov too [Mr. Green]
Back to top
User is offline
killerferret666
Premium Member
PostPosted: Mon Aug 21, 2017 9:31 pm    Post subject: Reply with quote Reply with quote including images
No but before I had the S bend with AFM of course.
Now I have a 400mm straight metal pipe to the filter which is right next to the air intake in the bodywork. I did wonder if this would make a difference!
It is a loud flutter. at 0.2 / 0.3 bar i swear it peaks. I did notice a slight flutter before the BOV went off today as well.
Just a lovely new noise then!
Back to top
User is offline
raptor95GTS
PostPosted: Fri Aug 25, 2017 3:33 pm    Post subject: Reply with quote Reply with quote including images
daft question. Have you re-plumbed the black and white VTA valve at the BOV? The side marked B should be on the passenger side. I had mine the other way round and it make that same noise (rev3 rhd)
Back to top
User is offline
Gazza_DJ
Premium Member
PostPosted: Fri Aug 25, 2017 3:57 pm    Post subject: Reply with quote Reply with quote including images
Is that retained for an aftermarket BOV like the OP has? I'm sure most aftermarket ones I've seen don't use the VTA?
Back to top
User is offline
raptor95GTS
PostPosted: Fri Aug 25, 2017 8:34 pm    Post subject: Reply with quote Reply with quote including images
some do and some dont, I dont know what the OP has fitted but the noise is what I had. Like I say, could be a daft question on my part [Smile]
Back to top
User is offline
killerferret666
Premium Member
PostPosted: Sat Aug 26, 2017 8:11 pm    Post subject: Reply with quote Reply with quote including images
The Bov was on my rev 2 originally and plumbed same way with only the one feed to it.
It is weird it now does it though. Boost between gear changes is it a bit slower to build back up I think as well.
Back to top
User is offline
androo007
Premium Member
PostPosted: Wed Aug 30, 2017 9:12 pm    Post subject: Reply with quote Reply with quote including images
Yeah it's not enough to make the bov pssssshhht so it flutters. Completely normal. I had an HKS that was soft and it hissed every gear change. Nowhere near as cool.
Back to top
User is offline
Display posts from previous:
Post new topic   Reply to topic       www.imoc.co.uk Forum Index -> MR2 MK2 1990 - 1999 NA & Turbo -> Mechanical All times are GMT
Page 1 of 1
Jump to:
