Ditching HT leads and dizzy for COP always a good idea?
Odin_S
Post by Odin_S »
I'm in two minds about doing this, I've been told that 1zz/2zz conversion will give me a bigger spark and more power. My goal is just over 400bhp fly.
However i see George's MR2 is still running OEM and is at 700+ and other big power 2s.
I guess I'm looking for the pros and cons, help me out :D
I've bought a 1zz loom, just to find the 4 coil packs now. What else do i need?
SonicSW20
Re: Ditching HT leads and dizzy for COP always a good idea?
Post by SonicSW20 »
Assume you have an aftermarket ECU? You'll need some way of taking a cam timing trigger if you want to remove the distributor completely, have a look at this Racer X kit as an example - http://racerxfabrication.com/mr2-celica ... il-on-plug
Odin_S
Post by Odin_S »
Very nice Gaz, i may look into this for the future. I have a Link G4
But just want to see who's done the conversion
rev2rich
Post by rev2rich »
I have done the conversion and the kit is basic had to re machine a few parts so they would work better but overall it was great and smiple
User avatar
JAAASH
Post by JAAASH »
In for the replies as im also interested in this.
_________________
"What the Deuce?!"
My MR2 - http://www.imoc.co.uk/forums/viewtopic.php?t=174494
androo007
Post by androo007 »
Yep. I have cops and 8 grade iridiums. Spark millions stronger and helped hugely after 350-400hp.
sky-net
Post by sky-net »
Aaron from ATS Racing stated in their website that our stock electric system is pretty strong and capable:
http://atsracing.net/Blog/View/23
A good COP system should be an advantage as it has a more recent design... But more pricey as well.
Al-sw20
Post by Al-sw20 »
COP can have tuning advantages with an aftermarket ecu.
You don't chase horsepower by upgrading ignition. All you need is a reliable spark. It's money that can be better spent elsewhere in the car.
mr2magic
Post by mr2magic »
Al-sw20 wrote:COP can have tuning advantages with an aftermarket ecu.
This! Things like a bigger or stronger spark are marketing gibberish. It makes no difference how hot or cold, large or small the spark is; if it's there at the right time it will ignite the mixture.
It is maybe important to note that COP do burn out and when they do they are expensive!
SonicSW20
Post by SonicSW20 »
mr2magic wrote: It makes no difference how hot or cold, large or small the spark is; if it's there at the right time it will ignite the mixture.
Well that's just not true. Selecting the wrong temperature spark plug will result in the plug overheating or excessive carbon buildup in a short period of time. . Overheating can be particularly dangerous as it can cause pre-ignition.
mr2magic
Post by mr2magic »
Gazza, don't mix up the temperature of the plug, which is a function of its design with regards to heat dissapation via the contact between plug and cylinder head and the quality of the spark itself.
Simlpy put...even if the spark is totaly weak and only just managed to be produced by the coil, if it is sustained within the combustion chamber at the right time it will ignite the mixture - it doesn't matter if it ist 35kV or 35MV
Marty J
Post by Marty J »
It's the cop from the 1zzfe that you need. I seem to recall that the 2zzfe uses a different setup.
If you want to keep a clean oem look, then you can fit a 5sfe oil pump which has the space for the trigger wheel sensor.
Also the trigger wheel pulley is 13521-88560.
Marty J
Post by Marty J »
Although it's a little bit long, I would recommend that you read this thread to get a better understanding of what's involved.
http://www.mr2oc.com/12-after-market-en ... worth.html
pbmr2
Post by pbmr2 »
The gen4 pump also has the sensor and the lower crank gear has teeth.
Stock setup on the gen4 also uses a cam sensor but it isn't really needed in a standalone setup.
Just options for using stock toyota parts for the trigger wheel and sensor.
Odin_S
Post by Odin_S »
Very interesting this guys, thanks. Going to take time and read once I'm home :thumleft:
User avatar
JAAASH
Post by JAAASH »
My mapper mentioned this to me last time I was there. Something about being able to time the spark better iirc.
_________________
"What the Deuce?!"
Al-sw20
Post by Al-sw20 »
Yep the spark either ignites at the right time or it doesn't.
You can't be a little bit pregnant.
User avatar
JAAASH
Post by JAAASH »
Al-sw20 wrote:You can't be a little bit pregnant.
Ye, thanks for that... :roll:
_________________
"What the Deuce?!"
Madabout
Post by Madabout »
I am no expert but this is exactly why people do it on the mx5 community I am mainly involved in.
androo007
Post by androo007 »
Spark blowout is a factor too.
