[Mk2] [NA] New N/a for daily. BAD BAD brakes!
Post new topic   Reply to topic       www.imoc.co.uk Forum Index -> MR2 MK2 1990 - 1999 NA & Turbo -> Mechanical
Author Message
Bear87
Premium Member
1992 Toyota MR2 Mk2 Turbo Rev2
PostPosted: Fri Aug 04, 2017 8:58 pm    Post subject: [Mk2] [NA] New N/a for daily. BAD BAD brakes! Reply with quote Reply with quote including images
hey guys,
so got myself a little rev 1 na (super cheap) while the turbo is off the road. Has done very little mileage with previous owner of 12 years with m.o.t's suggesting under 1000 miles a year.
I expected brakes to need to re seat and clean up the disc but they don't seem to have any power and are super spongy.
Have not had a chance to take a proper look yet but would it likely just need bleeding or is it a sign of seized calipers?
Also the steering wheel wont adjust up and down. Anyone come across this?
Brad
_________________
Smoke me a kipper. I'll be back for breakfast.
1992 Rev 2 Turbo Super Red
1991 Rev 1 N/A Steel Mist Grey (daily)
Back to top
User is offline
pbmr2
Premium Member
PostPosted: Mon Aug 14, 2017 7:29 am    Post subject: Reply with quote Reply with quote including images
sticky or stuck sliders, rusted into place pistons, old brake fluid, stuck handbrake cables and maybe handbrake mech on the calipers.
they would be the top things to look at.
The rev1 brakes are noticably worse than the rev2+ but at normal road speeds they should still work fine. the design of the sliding calipers tends to make them stick. pistons rust in place when not used for a long period. fluid goes off with time.
shoudln't need much more than a good going over and some proper redrubber grease on the sliders. then again if they are really bad they may need a rebuild. best investigate first.
Back to top
User is offline
Display posts from previous:
Post new topic   Reply to topic       www.imoc.co.uk Forum Index -> MR2 MK2 1990 - 1999 NA & Turbo -> Mechanical All times are GMT
Page 1 of 1
Jump to:
