Wheels studs
Wheels studs
is it the same wheels studs front and rear ? after fronts for longer
Re: Wheels studs
Help ! Iam confused. Coz in MR2- ben said its rear and frint same size spline. But on ebay listed items said only fir rear 14.6mm on front is slight smaller
Re: Wheels studs
Front and rear are the same in my experience. I did find that the replacement I bought from my local parts shop needed the splines tickling with a file before fitting as they were 0.4 mm to big but the spline pattern was correct.
If you on mr2oc search there for wheel stud and my posts and you may find a more in depth explanation with some pics as I remember replying to someone else.
Re: Wheels studs
Front and rear are the same spline size, eBay/universal studs are crap. The best extended studs you can get are ARP studs, part number ARP 100-7715. I think H-Tune are the cheapest UK support at the min, budget around £40 a corner
