Wheels studs
Post new topic   Reply to topic       www.imoc.co.uk Forum Index -> MR2 MK2 1990 - 1999 NA & Turbo
Author Message
Tomas_St
Premium Member
1992 Toyota MR2 Mk2 Turbo Rev2
PostPosted: Sat Aug 12, 2017 5:42 am    Post subject: Wheels studs Reply with quote Reply with quote including images
is it the same wheels studs front and rear ? after fronts for longer
Back to top
User is offline
Tomas_St
Premium Member
PostPosted: Sat Aug 12, 2017 8:47 pm    Post subject: Reply with quote Reply with quote including images
Help ! Iam confused. Coz in MR2- ben said its rear and frint same size spline. But on ebay listed items said only fir rear 14.6mm on front is slight smaller
Back to top
User is offline
abovetherim
1991 Toyota MR2 Mk2 NA Rev1
PostPosted: Sun Aug 13, 2017 8:43 am    Post subject: Reply with quote Reply with quote including images
Front and rear are the same in my experience. I did find that the replacement I bought from my local parts shop needed the splines tickling with a file before fitting as they were 0.4 mm to big but the spline pattern was correct.
If you on mr2oc search there for wheel stud and my posts and you may find a more in depth explanation with some pics as I remember replying to someone else.
Back to top
User is offline
C35Rob
Premium Member
1996 Toyota MR2 Mk2 Turbo Rev3
PostPosted: Sun Aug 13, 2017 9:15 am    Post subject: Reply with quote Reply with quote including images
Front and rear are the same spline size, eBay/universal studs are crap. The best extended studs you can get are ARP studs, part number ARP 100-7715. I think H-Tune are the cheapest UK support at the min, budget around 40 a corner
_________________
Back to top
User is offline
Display posts from previous:
Post new topic   Reply to topic       www.imoc.co.uk Forum Index -> MR2 MK2 1990 - 1999 NA & Turbo All times are GMT
Page 1 of 1
Jump to:
