[Mk2] [Generic] My New Install
madbasshunter
Re: [Mk2] [Generic] My New Install
Post by madbasshunter »
No I am not using power caps as they don't do a lot to be honest, and with the big 3 done I am at 14.8 volts at the sub amp on tick over even booming I was still in the 14's but I am making changes as have a 1ohm stable amp now :wink: . This will double my sub power from 500 watts RMS to 1000 watts and still 300 to the doors 8)
Have been talking to someone about deregulating my alternator :wink:
RyanRs wrote:
Skywalker wrote:explain how the coolant leaves the expansion tank and goes back into the coolant system?
Seriously , you don't know the answer to this? and you call yourself a car mechanic :shock:
2mad
Post by 2mad »
madbasshunter wrote:Have been talking to someone about deregulating my alternator :wink:
If you can boost the alternators power output .. big bassline will be had .. would love to have a look round your setup .. man after my own hart :thumleft:
Id say do a vid but all you hear is distortion on the sound track ..... keep it up though dude .. do love me some b-line .. since 94 in my cars :mrgreen:
benjo
Post by benjo »
Can anyone tell me which tweeter fit in oem place
parker455
Post by parker455 »
Don't suppose you've still got that confetti recaro clive..?
madbasshunter
I use the oem toyota tweeter mounts, remove the original tweeter and fit the new one, so most will fit
Sorry Tom I sold the Recaro SR3's to Mike when I got the SR5's :( which I do regret
madbasshunter
Haven't updated this for a while :oops:
There have been a lot of changes which mean its all being refitted with a few differences ;)
Decided as well as upgrading the charging I would do the same to the earth and as I am using the oem Toyota starter cable as an additional charging wire using a 0 gauge wire from alternator to starter cable, I decided to run another Toyota starter cable as earth. Starting at the stock earthing point behind the P/S box I have a 0 gauge from battery earth to body earth bolt, where the new wire is also attached, then runs down centre tunnel alongside starter cable
Then into engine bay alongside starter cable to the gearbox mount where its bolted down across from the engine earth
I have more earthing to add but the charging is looking good
Highest I have seen so far is 15.4v
RCA's remote and speaker wires are run between boot and cabin
and frunk is finally back together with the C-Tek charging plug connected to the battery but now in the passenger footwell so access isn't needed to the battery
17" spare only just fitted with a new 215/40 tyre :roll:
2mad
Post by 2mad »
Bass-line onboard :mrgreen:
Wicked :clap:
madbasshunter
Removing the charcoal carrier provided a good place for the audio fuse, 0 gauge cable goes from alternator to starter positive, then one cable to battery and the other to this fuse holder
Then from fuse holder into the boot
Using this screw in fitting
Amps are now in place, my old kac-ps521 sub amp now runs the doors, the covers will be back on soon
The amp seems happy with the voltage
I finally got round to fitting my temporary sub box (I purchased last year)
to find it put my amp into protect
Quick test of the voice coil showed
when it should be reading 4 ohms like the other speakers
madbasshunter
I dragged my kicker box out and rewired it from 4 ohms to 1 ohm this way the sub amp will be putting out 1000 watts RMS
Port fires over the headrest but I might put a fishnet headrest on instead :p
Found a tablet will fit in the phone holder in for the Toyobd1
madbasshunter
The external port seemed to beg for a fishnet headrest :D
So I added one on the passenger side which is perfect for the port to restyle the passengers hair :lol:
I prefer the solid headrest so run one of each now
madbasshunter
Sadly my kac-ps810d amp died and to be fair it didn't really feel like it was twice the power of the old amp. So I have gone pack to the old set up off the ps521 feeding 500w rms to the sub and the kac7251 putting 150w rms to each door
Its pretty obvious the other amp was never working properly from the day I bought it from a member on here, as its now louder and clearer but with nearly half the power it supposedly had :shocked: here is a bit of a demo
https://www.dropbox.com/s/w3dbsoylpgsmq ... d.mp4?dl=0
madbasshunter
Return to “ICE and Security”
