help with 97' turbo GEARBOX
Post new topic   Reply to topic       www.imoc.co.uk Forum Index -> MR2 MK2 1990 - 1999 NA & Turbo
Author Message
nige2307@virginmedia.com
PostPosted: Mon Jul 17, 2017 1:34 pm    Post subject: help with 97' turbo GEARBOX Reply with quote Reply with quote including images
got a reluctant gearbox ..2nd-3rd ok going down from 4th, but up in to 3rd i have to slow shift...
question is ..
new synchro or 2nd hand box?
and what should i expect regarding cost?
also.. how difficult would it be for a qualified mechanic to do.. ( limited gearbox experience )
any pointers/advice is appreciated [thumleft]
Back to top
User is offline
Hez
Premium Member
PostPosted: Mon Jul 17, 2017 2:48 pm    Post subject: Reply with quote Reply with quote including images
I would go for a 2nd hand box probably pick one up 2nd hand for 200-300 quid and I would expect it to cost about 200 quid labour. Shouldnt be a bad job for a qualified mechanic think the book time is 6 hours.
Back to top
User is offline
auzzam
Premium Member
PostPosted: Mon Jul 17, 2017 5:47 pm    Post subject: Reply with quote Reply with quote including images
this may be worth a go... when I first bought my mr2 the car would crunch going into third sometimes (2nd>3rd).
I figured the clutch pedal wasnt being pushed down far enough, so I removed my floor mat and problem was gone
Back to top
User is offline
cosmos
1999 Toyota MR2 Mk2 Turbo Rev5
PostPosted: Tue Jul 18, 2017 9:29 pm    Post subject: Gearbox Reply with quote Reply with quote including images
Seem to recall adjusting my actual clutch pedal at the pedal box inside the footwell to raise the bite point higher up the pedal travel as it was near the floor as opposed to half way, long shot!
Back to top
User is offline
PostPosted: Sun Aug 27, 2017 4:43 pm    Post subject: Reply with quote Reply with quote including images
SORTED... clutch pedal adjusted and cube in selector levers turned 90 degrees..
CHEERS.
Back to top
User is offline
raptor95GTS
PostPosted: Mon Aug 28, 2017 10:57 am    Post subject: Reply with quote Reply with quote including images
CHEERS.
what did you adjust with the selector levers?
Back to top
User is offline
Display posts from previous:
Post new topic   Reply to topic       www.imoc.co.uk Forum Index -> MR2 MK2 1990 - 1999 NA & Turbo All times are GMT
Page 1 of 1
Jump to:
