Link g3 + where to wire up map sensor??
caldridge7
Post by caldridge7 »
Hi guys just wondering if anyone can help with wiring my 7bar map sensor, it has a pig tail with it but the old air flow meter plug on the loom does connect right up to the map sensor.. Is this correct to do it like this or where should it be wired, really confused...
Hope some one can give a fool some guidance....
caldridge7
Re: Link g3 + where to wire up map sensor??
Bump
blogsy
Post by blogsy »
You should talk to Adrian at Fensport. There not that faraway from you and he's good with that ecu.
