Camry v6 Idler Pulley
Post new topic   Reply to topic       www.imoc.co.uk Forum Index -> MR2 MK1 1984-1989 NA & SC
Author Message
SuperRedMR2
1990 Toyota MR2 Mk1b
PostPosted: Tue Apr 04, 2017 11:36 am    Post subject: Camry v6 Idler Pulley Reply with quote Reply with quote including images
Hi,
Can anyone give me the part number for the camry idler pulley mod for the SC engine?
Back to top
User is offline
Ben
Premium Member
2001 BMW M5
PostPosted: Tue Apr 04, 2017 12:55 pm    Post subject: Reply with quote Reply with quote including images
Post's a few years old, but when I did the pulley mod on my SC I used the part number from this thread:
http://www.imoc.co.uk/forums/viewtopic.php?t=138871&highlight=camry+idler
_________________
Previous:
Back to top
User is offline
SuperRedMR2
PostPosted: Tue Apr 04, 2017 3:03 pm    Post subject: Reply with quote Reply with quote including images
Damn it! I went through all the threads yesterday with v6 idler and then didn't read the part number!
Back to top
User is offline
PW@Woodsport
IMOC Affiliated Company
PostPosted: Wed Apr 05, 2017 11:01 am    Post subject: Reply with quote Reply with quote including images
It's one of my mods, you should have just asked and I would have given it to you.
_________________
Back to top
User is offline
SuperRedMR2
PostPosted: Wed Apr 05, 2017 2:34 pm    Post subject: Reply with quote Reply with quote including images
you haven't got any available kicking around have you paul?
I'll be up at Teesside next week....
Back to top
User is offline
SuperRedMR2
PostPosted: Wed Apr 05, 2017 2:59 pm    Post subject: Reply with quote Reply with quote including images
Is this it?
http://www.ebay.co.uk/itm/Timing-Belt-Idler-Pulley-Camry-Es-Rx-300-Rx-1350362030-26806-/371709449362?hash=item568b9c1492:g:DFgAAOSwawpXrxsz
Back to top
User is offline
PW@Woodsport
PostPosted: Wed Apr 05, 2017 3:01 pm    Post subject: Reply with quote Reply with quote including images
Sorry I haven't got one in stock, but this is it and cheaper...
http://www.ebay.co.uk/itm/Timing-Belt-Idler-Pulley-for-TOYOTA-CAMRY-3-0-92-06-1MZ-FE-3VZ-FE-Petrol-ADL-/311831464979?hash=item489a9a8c13:g:8JwAAOSwol5YyDR4
Back to top
User is offline
SuperRedMR2
PostPosted: Wed Apr 05, 2017 9:08 pm    Post subject: Reply with quote Reply with quote including images
Thanks Paul!
Just ordered!
Back to top
User is offline
oukie
IMOC Organiser
1987 Toyota MR2 Mk1b
PostPosted: Sun Jul 02, 2017 3:36 pm    Post subject: Reply with quote Reply with quote including images
Bump, I've just ordered myself one of these also (thanks Paul)
My SC already had the Fensport kit fitted, but obviously using the Fensport supplied Ford item it is already failing after only a few thousand miles.
Chris
_________________
Mk1b White T-bar SC 1987, Mk1b White coupe Jan90, Mk1b White coupe Jan90 (spares), Mk1b Mica blue T-bar Mar90, Mk1b Mica blue T-bar,full climate control,Jan90, 5 mk1's [Smile]
Back to top
User is offline
PW@Woodsport
PostPosted: Mon Jul 03, 2017 5:41 am    Post subject: Reply with quote Reply with quote including images
You're welcome, I have no idea why they use that cheap plastic Ford part, probably comes down to costs, but the Camry idler isn't exactly expensive.
Back to top
User is offline
kaiowas
1985 Toyota MR2 Mk1a
PostPosted: Mon Jul 03, 2017 8:06 am    Post subject: Reply with quote Reply with quote including images
In all the years I sprinted a 4A-GZE I never had any problems with the plastic pulley. I always intended to swap it out for the Camry one but never got around to it because the Ford one worked fine for me. Is it possible that some people over tension the belt causing the Ford part to fail prematurely in some cases?
Back to top
User is offline
PW@Woodsport
PostPosted: Mon Jul 03, 2017 6:13 pm    Post subject: Reply with quote Reply with quote including images
Possibly, you will always get some that work fine without issue, however I have seen a LOT of Ford pulley failures over the years, it could well be slight over-tensioning causing that, but the Camry idler won't break no matter what tension you put on it.
Basically it's a crap plastic part that's just not fit for purpose in my opinion, I feel much better about having a factory all metal Toyota idler on there and we've seen zero failures since inventing that upgrade.
Back to top
User is offline
Display posts from previous:
Post new topic   Reply to topic       www.imoc.co.uk Forum Index -> MR2 MK1 1984-1989 NA & SC All times are GMT
Page 1 of 1
Jump to:
