Blue smoke on a cold start. Forged pistons
ashley
Re: Blue smoke on a cold start. Forged pistons
Post by ashley »
Standard compression ratio on a rev 3 is 8.5:1 from memory isn't it? Stock boost is just under 1 bar isn't it?
Are you running the stock ECU and using pump fuel?
GreddyMR2
Post by GreddyMR2 »
Mine is rev1. And if I remember correctly, stock cr is 8.8.
Yes, I am planning to be on a safe side and boost to 1bar.
I fitted walbro fuel pump, but still on stock ecu.
ashley
Post by ashley »
OK- so you've only upped you compression ratio slightly from 8.8 to 9:1
But you're going to run more boost than stock- so have you done anything to improve inter-cooling?
GreddyMR2
Post by GreddyMR2 »
I have ARC intercooler.
Like this one
http://i89.photobucket.com/albums/k217/ ... G_0555.jpg
bobhatton
Post by bobhatton »
I think the Rev 1 and 2 ran 8psi boost on 8.8:1 C/R then when the Rev3 went up to 12 psi boost the C/R went down to 8.5:1
So if you want to run at 15psi the ECU will be controlling on the knock sensor most of the time and you will have lower power.
I would use some octane booster, the NOS one is the best.
MR2 Rich
Post by MR2 Rich »
bobhatton wrote:I think the Rev 1 and 2 ran 8psi boost on 8.8:1 C/R then when the Rev3 went up to 12 psi boost the C/R went down to 8.5:1
Even with 99 octane fuel?
Maybe watch this before you make an informed decision on "octane boosters"
http://www.youtube.com/watch?v=zKxJfXfD6mg
No 2 :(
GreddyMR2
Post by GreddyMR2 »
I think meth injection should also help, right?
ashley
Post by ashley »
Just drop the boost you run, and use race fuel when you want to run more :thumleft:
(or buy some 8.5:1 pistons :eye: )
GreddyMR2
Post by GreddyMR2 »
To buy another pistons is way far out of my budget now :D
Don't want to lower a boost as I'm get used to 1bar already, so probably going 0,8bar will feel very slow... F**in wisecos...
I think it's too messy to run two different kind of fuels.
ashley
Post by ashley »
Water/ Meth injection then :thumleft:
GreddyMR2
Post by GreddyMR2 »
OK, finally car is running again.
I still have no smoke at all, but I only drove about 100km. I hope it will be fine now.
But another thing, the car now idles like with aftermarket cams. And vacuum is staying at around -35 when it was around -50 before. However, when I drive, it runs perfectly, sound is strange only on idle. I check vacuum hoses, all looks good. Idle valve connected, no error codes, everything looks fine. What more should I check?
Here is the video:
https://www.dropbox.com/s/g0sltgdbl6807iu/VIDEO0040.mp4
bobhatton
Post by bobhatton »
GreddyMR2 wrote:OK, finally car is running again.
Here is the video:
Sounds like the cam timimg may be out, re check it again
GreddyMR2
Post by GreddyMR2 »
Here is the video:
God damn it... You mean timing belt, right? But if it's working well when I drive, is it a problem?
I have N/A cams and cam gear on exhaust side retarded by 5 deg.
bobhatton
Post by bobhatton »
Here is the video:
deg.
I would set the cams up as stock to run the engine in and see how it goes. Then if you must change the cam timing do it a small amount at a time.
GreddyMR2
Post by GreddyMR2 »
Long time from the last post here, but the topic is right.
From the last time I posted here car is running very well and strong and it's far from death as somebody wrote. But still one thing is annoying me.
And it will probably be due to larger piston to cylinder gap which I wrote here (current gap is 0.09mm when recommended gap for wisecos is 0.07mm).
The thing is that I get some blue smoke once the engine is started after a while and makes smoking when driving untill it's warmed up. Once the engine is at operating temp, there is no any sign of smoke. And yes, it uses a bit of oil which is the most annoying thing.
So am I right thinking that 0.09mm gap cause burning oil while the engine is cold? Maybe it is common with all forged pistons to consume a bit of oil?
Odin_S
Post by Odin_S »
How much oil over 1000km?
GreddyMR2
Post by GreddyMR2 »
It's a bit hard to say as my speedo isn't working, but about 1l.
SonicSW20
Post by SonicSW20 »
My friends smells like an oil refinery when you drive behind it :lol:
androo007
Post by androo007 »
Thats about the same as a BMW then :lol:
Sounds a bit much tbh. I dont use a drop
GreddyMR2
Post by GreddyMR2 »
androo007 wrote:Thats about the same as a BMW then :lol:
Do you run with forged pistons?
