Hi wondered why my tubby was making a lot of noise ,turns out the dump valve is stuck wide open ! Is this common and how to cure it please.
Cheers Mike.
[Mk2] [Turbo] Open dump valve , stuck.
Re: [Mk2] [Turbo] Open dump valve , stuck.
Hi
Are you just running the stock recirculation valve?
You could disassemble clean and rebuild and grease the piston.
Suk dump valve.
Don't know f it's standard or where it is?
Re: Suk dump valve.
micarus wrote:Don't know f it's standard or where it is?
if you don't know if its standard or where it is, how do you know its stuck open?
Stuck dump valve
One of the mechanics at Tatton Park told me when I asked him why it was so noisy.
