Air flow question
Post new topic   Reply to topic       www.imoc.co.uk Forum Index -> MR2 MK1 1984-1989 NA & SC
Author Message
CurtisRW
PostPosted: Sat May 06, 2017 11:02 am    Post subject: Air flow question Reply with quote Reply with quote including images
Just wandering if anyone can point me in the direction of some info or tell me about the air flow for the Mk1b?
I was thinking of getting K&N air filter but wasn't sure how effective this would be since it would surely no longer be utilizing the side fins which are where the stock system pulls the air from? - am I right?
So I was thinking about getting one of those side air scoops to pull air in directly where the filter would be but have since read that the air comes in from underneath the car and that one of these scoops would be a bad idea as it will disrupt the air flow?
Can anyone confirm the above? whats a good solution? what are you all doing for n/a intakes?
Thanks for any help [Very Happy]
Back to top
User is offline
jimi
1988 Toyota MR2 Mk1b
PostPosted: Sat May 06, 2017 9:06 pm    Post subject: Reply with quote Reply with quote including images
The only real difference fitting a cone filter (of any make) to a MK1 is increased induction noise and appearance, other than that there's no reason to change from the standard set up, there's no appreciable power gain to be made.
In my case I reckon I lost bottom end torque and after 6-8 months went back to the standard 1b setup (less the resonator box, which does nothing anyway)
IMHO you'd be better off spending the money on overhauling the brakes or buying braided brake lines [Wink]
Back to top
User is offline
Lauren
PostPosted: Sat May 06, 2017 9:58 pm    Post subject: Reply with quote Reply with quote including images
Just stick the cone filter in the boot where it mounts to the metal pipe that comes through the boot firewall. Then pull the sponge that is sitting over the inner wheel arch helping it to rot and you'll get a bit of induction noise in the cabin. Best of both worlds. [thumbsup]
Or you can just stick it straight on the throttle body, it'll sound good. There's loads of airflow from underneath the engine so don't worry about scoops.
_________________
2013 GT86 Injen Induction. Volks Racing TE37s & TRD Aero Fins, Mega sounds. TEIN Street Flex 5/6kg, TEIN EDFC Active Pro. Tuning Developments Remap 4-1 Manifold, TD resonated exhaust, decat/overpipe, AP Racing 4 Pot front brakes. [lover]
Back to top
User is offline
Display posts from previous:
Post new topic   Reply to topic       www.imoc.co.uk Forum Index -> MR2 MK1 1984-1989 NA & SC All times are GMT
Page 1 of 1
Jump to:
