[Mk2] [NA] Non starter
Wraith
Post by Wraith »
Hi all,
I have owned 7 MR2's now over 15 years.
I have just pick up a 1998 rev 4 t-bar NA. Unfortunately it will not start and I'm hoping someone can help.
The engine turns over, I have a spark and I can hear the fuel pump running for a couple of seconds after each time I try to start it.
Does anyone know of common faults etc or best place to start looking?
Paul
Bear87
Re: [Mk2] [NA] Non starter
Post by Bear87 »
Hi paul.
Normal basics i would check is EFI 15amp fuse i know this stops the injectors but cant say if it stops fuel pump.
Have you checked engine compression?
Base timing? Maybe it slipped a tooth?
If you have fuel, spark and timing there isnt alot to stop it from starting.
Check the capacitors on the ecu?
Does the car have an immobiliser?
Is the car automatic? Faulty park switch maybe?
Just my 2p but hope it may help :thumleft:
Wraith
Post by Wraith »
Thanks for the advice. Will check the efi fuse. Do you know the location at all?
It is a manual by the way.
Paul
Bear87
Post by Bear87 »
Yes mate its in the engine bay passenger side rear (boot end) the cover is labled. May be worth giving all the fuses and relays a check and a wiggle.
Wraith
Post by Wraith »
Ah, yes checked all those!
I will keep hunting.
Thanks again
Bear87
Post by Bear87 »
Have you checked for fault codes with the toyota service tool (paperclip)
Sorry forgot to mention that :roll:
Wraith
Post by Wraith »
No I haven't yet. Have a code reader but not correct plug! Seen the paperclip method so will give that a try.
Bear87
Post by Bear87 »
Wraith wrote:No I haven't yet. Have a code reader but not correct plug! Seen the paperclip method so will give that a try.
Our cars run a obd1 system so obd2 code readers wont actually work. If they do they wont tell you anymore that the flash codes on dash.
Let me know if you get stuck or need to know what the codes mean :thumleft:
Wraith
Post by Wraith »
That's great. Thanks for your help. Will let you know how I get on.
alanmr2turbo
Post by alanmr2turbo »
had a similar issues with one car i bought to sell on. I bought it as a none runner but a REV3 delivered for £150 was to good to pass up on as i would get more money back scrapping it if it never started.
Had fuel and spark but wouldn't start.
Changed the coil pack and ignitor all in one and off she started. Just don't forget to bolt it in place as the bracket is it's earthing.
The spark was obviously not a good enough one to start the car.
£150 turned into £2k over night LOL
tiff_lee
Post by tiff_lee »
So it's turning over with a spark but not firing, are the plugs wet?
Wraith
Post by Wraith »
I have noticed the alternator has seized and snapped the belt. What sort of job is it to replace the alternator? I can't see any way of getting it out without dismantling half the car!
Bear87
Post by Bear87 »
You can do the alternator from side/ underneath with wheel off. It is tight and from memory it fails on the block or a bracket but with a small pry bar it does come out. The bracket is ALWAYS tight as hell but persistance does pay off. Took me two cups of tea three fags and about two hours :thumleft:
Wraith
Post by Wraith »
Thanks for that. I don't smoke but think I might by the time I've done it! ](*,)
qwakers
Post by qwakers »
when i did my alternator i happened to have the rear crossmember and suspension strut off the car. it was a 10 min job to get the alternator off. if i did it again i would definitely take the crossmember off for access, it doesnt take long and it makes is easy.
Wraith
Post by Wraith »
Ok, so thought I should share this for anyone with similar starting issues.
After checking everything everything over the past couple of weeks I established there was fuel getting g to the fuel rail, I had a spark and compression so it had to be a breather or vacuum problem.
Turned out the fuel rail actuator was seized.
A bit of WD40 and opening and closing the actuator manually, it fired up first time!
tiff_lee
Post by tiff_lee »
Wraith wrote:Ok, so thought I should share this for anyone with similar starting issues.
Glad you sorted it but I did ask
tiff_lee wrote:So it's turning over with a spark but not firing, are the plugs wet?
that would of given it away without the need for compression testing and what not but that's moot now it's sorted anyhow.
