shim bank and valve adjustment tool
Goto page Previous  1, 2, 3
Post new topic   Reply to topic       www.imoc.co.uk Forum Index -> MR2 MK1 1984-1989 NA & SC
Author Message
LimeyMk1
1987 Toyota MR2 Mk1b
PostPosted: Sat Oct 26, 2013 6:34 pm    Post subject: Reply with quote Reply with quote including images
The hallowed shim bank is with me now. [Mr. Green]
Back to top
User is offline
Mavros
Premium Member
PostPosted: Mon Oct 28, 2013 6:21 pm    Post subject: Reply with quote Reply with quote including images
Limey,
Can I have dibs on it when you've finished?
Back to top
User is offline
cattouchin
PostPosted: Sun Dec 15, 2013 4:05 pm    Post subject: Reply with quote Reply with quote including images
I have a set of shims from an engine I stripped down, i'll stick them in the post to add to the collection if whoever has the shim bank at the moment can PM with an address.
Back to top
User is offline
Mavros
Premium Member
PostPosted: Wed Apr 30, 2014 4:15 pm    Post subject: Reply with quote Reply with quote including images
I've got the shim bank at the moment but I'm about to send it off to Limey. Probably best if you send yours onto him.
Back to top
User is offline
LimeyMk1
PostPosted: Sat May 03, 2014 11:58 pm    Post subject: Reply with quote Reply with quote including images
Cattouchin sent them to me, all ready to be added to the bank, just got to measure them up to go in the right bags. [Cool]
Back to top
User is offline
Mavros
Premium Member
PostPosted: Wed May 07, 2014 7:56 am    Post subject: Reply with quote Reply with quote including images
Can you let me know if you have any of the following: 2.5, 2.55 or 2.6 as I seem to need these more than anything else.
Back to top
User is offline
LimeyMk1
PostPosted: Wed May 07, 2014 8:41 am    Post subject: Reply with quote Reply with quote including images
I'll measure them up this evening and let you know. [thumleft] I have an old 3SGE head in the garage still with shims, I'll check to see if they are the same as the 4AGE and measure them up too.
Back to top
User is offline
Mavros
Premium Member
PostPosted: Wed May 07, 2014 2:25 pm    Post subject: Reply with quote Reply with quote including images
Cheers mate,
I did contact my local dealer but they want 10 + VAT for each shim!
Back to top
User is offline
LimeyMk1
PostPosted: Wed May 07, 2014 2:32 pm    Post subject: Reply with quote Reply with quote including images
Mavros wrote:
Cheers mate,
Yup, that's about the going rate unfortunately. [Sad]
Back to top
User is offline
LimeyMk1
PostPosted: Sun May 11, 2014 6:35 pm    Post subject: Reply with quote Reply with quote including images
Sorry about the delay, 2.88 is the smallest I have. [Sad]
Back to top
User is offline
Lauren
PostPosted: Sun May 11, 2014 7:47 pm    Post subject: Reply with quote Reply with quote including images
I've got a load but they are in Macclesfield. I think some of them are marked up.
Depends where you are, you could pop over to Mark's workshop and have a look.
I won't have time to look myself unfortunately. I thought I might have been down there this weekend working on the AE86, but didn't manage it.
I did ask to see if Mark can bring some home, but he's not sure where they are!
Sorry not much help unless you can pop over there really. If you're not in a rush I can have a look when I next get down there, but it might not be for a few weeks.
I'll ask Mark to have a quick look for them for you.
_________________
2013 GT86 Injen Induction. Volks Racing TE37s & TRD Aero Fins, Mega sounds. TEIN Street Flex 5/6kg, TEIN EDFC Active Pro. Tuning Developments Remap 4-1 Manifold, TD resonated exhaust, decat/overpipe, AP Racing 4 Pot front brakes. [lover]
Back to top
User is offline
Mavros
Premium Member
PostPosted: Tue May 13, 2014 8:35 am    Post subject: Reply with quote Reply with quote including images
Much appreciated Lauren,
I'll wait for you to check them when you get round there.
Back to top
User is offline
JamesDaniel80
Premium Member
PostPosted: Tue May 13, 2014 1:57 pm    Post subject: Reply with quote Reply with quote including images
Hi,
I've been pointed in your direction because I'm in need of some valve shims...
I have a list of the ones I need (there are 14 in total with thicknesses varying between 3mm and 3.3mm).
Who do I need to go to, to make a purchase?
Cheers!
James
Back to top
User is offline
elbon50
PostPosted: Tue May 13, 2014 3:03 pm    Post subject: Reply with quote Reply with quote including images
JamesDaniel80 wrote:
Hi,
Cheers!
James
Suggest you send a PM to LimeyMk1 James [thumleft]
Back to top
User is offline
Lauren
PostPosted: Tue May 13, 2014 7:20 pm    Post subject: Reply with quote Reply with quote including images
Mark has had a look but there are just the buckets, not the shims I'm afraid. Tom may know where they are.
I will have a look when I'm next down the workshop to work on the AE86, but I'm not sure when that will be. I might get a chance on the bank holiday weekend. I know we have at least three sets of shims in all as Tom got them all, measured them and used the appropriate ones to build my engine.
Back to top
User is offline
Polypedates
Premium Member
1988 Toyota MR2 Mk1b
PostPosted: Fri Nov 28, 2014 5:59 pm    Post subject: Reply with quote Reply with quote including images
Hello, I am after the shim bank and shim adjustment tool if available please? Here's hoping Limey still has it as I am not far from him...
_________________
Punish your machines
'76 Citroen CX Pallas(Show queen)
'79 Citroen CX Athena (French mistress)
'87 MR2 T-Bar (interminable resto project)
'99 Accord Type-R (family bus)
'00 Ford Racing Puma (daily driver)
Back to top
User is offline
JamesDaniel80
Premium Member
PostPosted: Wed Dec 03, 2014 1:22 pm    Post subject: Reply with quote Reply with quote including images
Hi,
I've just sent the hallowed shim bank back to Limey so it should be with you soon.
Back to top
User is offline
LimeyMk1
PostPosted: Wed Dec 03, 2014 3:15 pm    Post subject: Reply with quote Reply with quote including images
Hi,
[thumleft] Cheers James.
Back to top
User is offline
mark35
PostPosted: Thu Oct 27, 2016 8:02 pm    Post subject: Valve shims Reply with quote Reply with quote including images
Can anyone help with valve shims.
After 0.118 and 0.123 shims
Back to top
User is offline
MaryWard
PostPosted: Tue May 02, 2017 7:45 am    Post subject: Reply with quote Reply with quote including images
That's really helpful. I have plenty of shims & buckets in my basement and I could send them away, since I am not using them. Thanks for sharing!
Back to top
User is offline
Display posts from previous:
Post new topic   Reply to topic       www.imoc.co.uk Forum Index -> MR2 MK1 1984-1989 NA & SC All times are GMT
Page 3 of 3
Jump to:
