View previous topic :: View next topic |
Author |
Message |
autobody
Joined: 12 Jan 2008 Posts: 483 Location: Manchester Feedback Score: 9
1988 Toyota MR2 Mk1 SC
Posted: Wed Aug 03, 2016 9:29 am Post subject: knock sensor |
Question for the SC owners - is there any other knock sensor that will work with the 4agze?
I am getting a error code 52 and I am unable to find a replacement, I have contacted Toyota and been told its discontinued, this is the part number I have 89615-17010.
I think it may be a case of holding out for a used one but I would be interested to know what others have done.
p.s. if you do have a spare knock sensor I will be happy to buy it.
Back to top |
kaiowas
Joined: 07 Jun 2005 Posts: 1945 Location: Norfolk Feedback Score: 10
1985 Toyota MR2 Mk1a
Posted: Wed Aug 03, 2016 10:05 am Post subject: |
TCB sell various knock sensors for Toyotas, I'm pretty sure one of them will be the right one although none of them are listed for the 4A-GZE
Think it might be the QIC 916 although it's probably best to give them a call and check rather than ordering one blindly.
Back to top |
autobody
Posted: Wed Aug 03, 2016 10:56 am Post subject: |
Thanks, just given tcb a call and are currently checking if it fits.
Back to top |
autobody
Posted: Thu Aug 11, 2016 7:59 pm Post subject: |
TCB have said the QIC 916 knock sensor will not work as it has different frequency readings. They don't stock 4agze knock sensors.
But I have now got a second hand unit. (Hope it works) I am going to temp to fit this in on Sunday.
Can I ask if other have done this job what was required? Is it accessable under the car? Do I need to remove any items to get to the knock sensor. Any tips appreciated.
Back to top |
kaiowas
Posted: Fri Aug 12, 2016 9:56 am Post subject: |
From memory it should be easy enough and accessible from underneath without removing anything although some contortion may be required, you should certainly be able to get the socket on, I just can remember how easy it is to find enough space to swing a ratchet. Oh and make sure you have a deep socket of the appropriate size, a standard socket won't cut it.
Also take care with the wiring/connector when unplugging the old one. Not sure if I've just been unlucky but all the GZE looms I've had have been particularly fragile in this area.
Back to top |
autobody
Posted: Sat Aug 13, 2016 10:36 pm Post subject: |
Update: replacment knock sensor fitted and looks to have done the trick. I have a small coolent leak at the front so only took the car behind my house. Drives much much better and no engine light.
To confirm, 27mm deep socket used and a small extension. Found I had just about enough room.
Thanks for your help kaiowas
Back to top |
autobody
Posted: Sat Aug 13, 2016 10:41 pm Post subject: |
Here is a pic of the knock sensor.
Both had Toyota markings on them. The top one came off the car and the bottom one was a replacement. Look similar but the bottom one was longer slightly.
Back to top |
jayelem
Joined: 17 Oct 2014 Posts: 51 Location: norfolk Feedback Score: 0
1989 Toyota MR2 Mk1 SC
Posted: Fri Apr 28, 2017 12:17 am Post subject: |
could do with one myself!
Back to top |
jon_st205
Posted: Fri Apr 28, 2017 4:06 pm Post subject: |
Let me dig around, I'm sure I have one somewhere.
Back to top |
jayelem
Posted: Sat Apr 29, 2017 2:45 pm Post subject: |
ive even crossed my balls in hope!
Back to top |
jayelem
Posted: Mon May 01, 2017 12:34 am Post subject: |
Bank holiday bump!
Back to top |
SuperRedMR2
Joined: 16 May 2005 Posts: 5480 Location: Wickford, Essex Feedback Score: 8
1990 Toyota MR2 Mk1b
Posted: Mon Dec 11, 2017 3:22 pm Post subject: |
Has anyone else got a spare?
Back to top |
