[Mk2] [Generic] Reducing front end lift and generally improving front end grip
Goto page Previous  1, 2, 3, 4, 5, 6
Post new topic   Reply to topic       www.imoc.co.uk Forum Index -> MR2 MK2 1990 - 1999 NA & Turbo -> Modifications
Author Message
Magic Beans
Premium Member
PostPosted: Wed Jan 08, 2014 1:36 pm    Post subject: Reply with quote Reply with quote including images
ads wrote:
less drag and lift from bulkhead
From what I've read the approach of angling the rad and using a vented Border front bumper is the optimum approach. That and proper flat underbody panels, like the EMS offerings they made a while back.
If I ever had another MR2 I'd focus solely on function first and then work styling around it, if at all possible.
_________________
The Mule(s) - http://www.imoc.co.uk/forums/viewtopic.php?t=159087
Back to top
User is offline
andylaurence
1990 Toyota MR2
PostPosted: Sun Jan 12, 2014 9:28 pm    Post subject: Reply with quote Reply with quote including images
Venting into the front wheel wells? Radiator efficiency depends on airflow, which is characterised by a pressure difference. As a result, greater cooling is achieved by venting the air to a lower pressure area and taking it from a high pressure area. The bumper is a high pressure area, especially with a splitter fitted, but the wheel wells are not traditionally high pressure areas. In fact, if you look at many race cars, they have vents on the top of the wheel arches to bleed the high pressure air from inside the wheel arch. A traditionally low pressure area is the bonnet, which is generally convex. I'd wager you'll get better cooling, lower drag and less lift if you vent the air out through the bonnet.
Back to top
User is offline
Magic Beans
Premium Member
PostPosted: Fri Apr 21, 2017 12:32 pm    Post subject: Reply with quote Reply with quote including images
Funnily enough, I now do and this is my plan. Watch this space..
And this space too: http://www.imoc.co.uk/forums/viewtopic.php?t=159087&start=2520
Back to top
User is offline
Display posts from previous:
Post new topic   Reply to topic       www.imoc.co.uk Forum Index -> MR2 MK2 1990 - 1999 NA & Turbo -> Modifications All times are GMT
Page 6 of 6
Jump to:
