Thought I'd post this as it may help someone
If you take your car to a specialist/belligerent ape with expensive tools
Who picks up wrong size Allen key and rounds all six screws,
This is what you do,first get the right size bit and knock it in with a hammer
Then use ratchet,is that doesn't work use a slightly larger torx bit
And use same method this got 3 out leaving 2 that where completely
Donald ducked, using t20 bits mix some kem fix from screwfix
And dip bits in ther hamer them in, leave to set for 30 mins then simply
Use ratchet to un do, then like borat GREAT SUCCESS
Removing momo steering wheel screws
Too weird to live, to rare to die
Re: Removing momo steering wheel screws
I just drilled them out when I had a similar problem. They are made from a very soft metal.
i cut a slit in one of mine and used a screwdriver. Damaged the outer ring but bought another for a fiver from ebay
i have a full bag of spares of these that you can have free of charge if you want them
as said above, drill them out. or invest in an impact screwdriver, they come in really handy for shocking free stubborn fastners
Thanks Allan I've ordered 6 new ones £2.60 on eBay but I will
Be wanting my dash doing when car goes to Paul woods
I'm a joiner so I've got impact drives but heads where completely rounded
Thanks for comments
Thanks for comments
benjo wrote:Thanks Allan I've ordered 6 new ones £2.60 on eBay but I will
Thanks for comments
no problem mate just let me know when and ill go collect it from paul
