JDM Import Rev 2 Turbo - 5SGTE build
Re: JDM Import Rev 2 Turbo - Megasquirt install. Anti lag. 2 step.
:shock:
Nice work!
JD
Post by JD »
Lovely. Black looks best when it's ultra shiny.
androo007
Post by androo007 »
WOW!!!!
I've been thinking about getting a DA polisher, but a self proclaimed virgin to it..... never know what to buy and get scared off.
rossonza
Premium Member
Post by rossonza »
androo007 wrote:WOW!!!!
you wait until ive done another few passes and put wax on her haha.
im using a dodojuice da. hexlogic 5inch pad. and megs m105 and m205. collinite wax. not an expensive setup. and i think worth the money.
rossonza
Premium Member
Post by rossonza »
anything else worth doing whilst heads off? ill be painting cam cover and repainting coolant pipes etc. i thought maybe timing belt?tvis removal?
rossonza
Premium Member
Post by rossonza »
Ok... so me asking what mods to do whilst heads off may have jinxed me :cry: :cry: :cry: :cry: :cry:
Started initial strip down today with the help of my friend steve:
rusty cams and chocolate milk looking oil from dipstick.... im thinking bottom end is rusted.. but need to check. if it is im guessing this engines 100% toast. not cool :-(
can the sump be removed to check big end bearings in situ or do i have to remove a lot of stuff?
#-o [/img]
Madabout
Post by Madabout »
I'm afraid I cannot help with the question but good luck with the project.
I've just got a Rev3 mr2 turbo and mainly into my mx5s including some high powered turbo'd, supercharged amongst them.
Mine is a bit of a project too.
If you need the outer sills I think the seller on eBay is MR2-Ben. Has a website with lots of other parts too. When you get any parts I would recommend the replacement bolts Ben does to replace the Phillips cam cover screws.
Although mine is a rev3 turbo it had a refreshed/uprated rev2 turbo engine fitted 8000 miles ago with the rev3 turbo, engine management, larger injectors, etc. so I guess similar direction you are going.
androo007
Post by androo007 »
I believe you can yes but it's quite quick to drop the engine too.
Not all bad..... you still have the costly parts at your disposal:
Gearbox
Turbo
All ancillaries
So all you really need is the engine - probability 500 bones. Maybe less.
Or just a good excuse to strip down snd forge the engine :-)
rossonza
Premium Member
Post by rossonza »
tempted by rev3 swap engine/ecu swap.
this engine worth anythimg to anyone in current state?
markstevieandmads
Post by markstevieandmads »
I was thinking of going for a rebuild so would be interested in it if it could be rebuilt.
androo007
Post by androo007 »
I'm not sure really. It'd be hard to say. I'd imagine if rust on the bores then no good really even as a block unless a light bore and home would clean it up. But the what about the oil and water gallaries? Not sure.... I'm no expert to advise
When I went forged I used a rev 2 bottom end and kept rev 3 top for my own reasons, could be the same use for you perhaps, with a rebuild of course.
rossonza
Premium Member
Post by rossonza »
thoughts on taking parts from this engine. and using it on my block?
http://www.ebay.co.uk/itm/262807454776
rossonza
Premium Member
Post by rossonza »
the guy that gave me the car has said i can have the 2 sets of spare cams he has for it. so one less thing.
really need to drop the sump and check pistons/bores. see what actually needs replacing.
Draven
Post by Draven »
Personally if you are planning on keeping / using this engine. I would drop the whole thing and strip it down check all the oil galleries and condition of the bores, bottom end etc. if the rust is that bad it'll probably have got all over.
rossonza
Premium Member
Post by rossonza »
Draven wrote:Personally if you are planning on keeping / using this engine. I would drop the whole thing and strip it down check all the oil galleries and condition of the bores, bottom end etc. if the rust is that bad it'll probably have got all over.
is the plan. going to try and drop it next weekend. be a shame to scrap it if its saveable.
rossonza
Premium Member
Post by rossonza »
didnt manage to drop the engine, ended up working overtime all weekend.
theres an engine ive got lined up so im waiting to see if it pans out. hopefully updates soon.
rossonza
Premium Member
Post by rossonza »
deposit down on a rev2 engine. fingers crossed i can get it swapped ASAP. i want to hear the thing run after 6 years. Sills taken back seat due to my itch to turn the car over lol. :thumleft:
rossonza
Premium Member
Post by rossonza »
had a poke at the sills.....wish i hadnt :P
then i took the side vent off to look there (id read it can rust around the vent) luckily its solid. also the subframe and suspension components just have surface rust / dirt on them. so ill be cleaning and painting what i can whilst the welding gets done on the sills.
passenger side is less rusty and for some reason only drivers rear arch is rusted a bit.
trying to locate a mig to borrow to get it welded up, going to buy repair panels (just the drivers side for now) and get to it whilst we still have these long evenings.
Magic Beans
Post by Magic Beans »
Looks familiar :(
They fix up well and if you're handy with a welder the replacements you can buy are really good.
rossonza
Premium Member
Post by rossonza »
Magic Beans wrote:Looks familiar :(
im excited to finally get stuck in :-)
