[Mk2] [Turbo] Rev 2 Turbo not holding boost to redline
Post new topic   Reply to topic       www.imoc.co.uk Forum Index -> MR2 MK2 1990 - 1999 NA & Turbo -> Modifications
Author Message
manuelk1
Premium Member
PostPosted: Thu Mar 02, 2017 12:45 pm    Post subject: [Mk2] [Turbo] Rev 2 Turbo not holding boost to redline Reply with quote Reply with quote including images
Hi guys I wonder if someone can help.
I've got a rev 2 turbo with a CT20B turbo, de-cat, hks fcd, manual boost controller which is set at 1.0 bar of boost. However when under full throttle it hits 1 bar of boost but doesnt hold to the red line it dies down to between 0.8 and 0.9 bar. Any ideas why its not holding 1 bar to redline?
Kieran
Back to top
User is offline
markstevieandmads
PostPosted: Thu Mar 02, 2017 2:42 pm    Post subject: Reply with quote Reply with quote including images
Are u sure its a ct20b? Get a pic up
Back to top
User is offline
manuelk1
Premium Member
PostPosted: Thu Mar 02, 2017 2:48 pm    Post subject: Reply with quote Reply with quote including images
Not got a pic but 100% it's a ct20b mate
Back to top
User is offline
markstevieandmads
PostPosted: Thu Mar 02, 2017 3:09 pm    Post subject: Reply with quote Reply with quote including images
Id say boost leak then
Back to top
User is offline
manuelk1
Premium Member
PostPosted: Thu Mar 02, 2017 3:21 pm    Post subject: Reply with quote Reply with quote including images
Will pressure check the system and report back, cheers buddy [thumleft]
Back to top
User is offline
markstevieandmads
PostPosted: Thu Mar 02, 2017 3:35 pm    Post subject: Reply with quote Reply with quote including images
Also check the wastegate isnt fouling on the decat
Back to top
User is offline
manuelk1
Premium Member
PostPosted: Mon Mar 13, 2017 11:44 am    Post subject: Reply with quote Reply with quote including images
no boost leak found. waste gate operating as it should and isn't fowling the down pipe!
Back to top
User is offline
cooper514
Premium Member
PostPosted: Sat Mar 18, 2017 9:31 am    Post subject: Reply with quote Reply with quote including images
Turn it up a bit more it will spike and come back down
Back to top
User is offline
robbie_742003
1996 Toyota MR2 Mk2 Turbo Rev3
PostPosted: Sun Mar 19, 2017 8:38 pm    Post subject: Reply with quote Reply with quote including images
It's not holding for a reason, I'd investigate further before upping the boost, try to get it in somewhere. Any fault codes?
Back to top
User is offline
manuelk1
Premium Member
PostPosted: Mon Mar 20, 2017 6:12 pm    Post subject: Reply with quote Reply with quote including images
No fault codes atall found, it also over boosts past 1.2 bar at high speed when applying the throttle in 5th gear which leads me to believe it could be the mbc which isnt working correctly?
Back to top
User is offline
robbie_742003
PostPosted: Mon Mar 20, 2017 7:55 pm    Post subject: Reply with quote Reply with quote including images
Its possible, what boost controller are you using? 17.5 PSI is too much without cooling mods and other supporting mods and could result in damage mate.
Rob
Back to top
User is offline
manuelk1
Premium Member
PostPosted: Mon Mar 20, 2017 9:38 pm    Post subject: Reply with quote Reply with quote including images
It's a Mumsby developments mbc. It's set to 1 bar mate but as I say over boots at high speed in 5th.
Back to top
User is offline
Display posts from previous:
Post new topic   Reply to topic       www.imoc.co.uk Forum Index -> MR2 MK2 1990 - 1999 NA & Turbo -> Modifications All times are GMT
Page 1 of 1
Jump to:
