[Mk2] [Turbo] '3.4W test bulb' specified in service manual for testing coolant gauge
Post new topic   Reply to topic       www.imoc.co.uk Forum Index -> MR2 MK2 1990 - 1999 NA & Turbo -> Electrical
Author Message
toecutter
1992 Toyota MR2 Mk2 Turbo Rev2
PostPosted: Thu Mar 16, 2017 5:07 pm    Post subject: [Mk2] [Turbo] '3.4W test bulb' specified in service manual for testing coolant gauge Reply with quote Reply with quote including images
I want to test the operation of my coolant gauge. The service manual covers this on page BE-55.
It specifies a '3.4W test bulb' to be used in the procedure (ground the harness connector through the bulb and the gauge should show hot).
Does it have to be exactly 3.4W? Tried a parts place and they didn't have any.
Back to top
User is offline
markstevieandmads
PostPosted: Thu Mar 16, 2017 6:13 pm    Post subject: Reply with quote Reply with quote including images
Should be able to work out what resistor is needed instead of a bulb.
All i can remember is v=ir which is currentxresistance =voltage. In this case it doesnt help lol
Shinny is an electrical genius so im sure he be around to tell you.
Back to top
User is offline
markstevieandmads
PostPosted: Thu Mar 16, 2017 6:16 pm    Post subject: Reply with quote Reply with quote including images
Just used an online calculator that does ohms law and putting in 12v and 3.4watts it equates to a 43ohm resistor?
Not sure if thats right tho.
Back to top
User is offline
Display posts from previous:
Post new topic   Reply to topic       www.imoc.co.uk Forum Index -> MR2 MK2 1990 - 1999 NA & Turbo -> Electrical All times are GMT
Page 1 of 1
Jump to:
