Spring Rates
Post new topic   Reply to topic       www.imoc.co.uk Forum Index -> MR2 MK1 1984-1989 NA & SC
Author Message
SuperRedMR2
1990 Toyota MR2 Mk1b
PostPosted: Mon Mar 06, 2017 12:04 pm    Post subject: Spring Rates Reply with quote Reply with quote including images
Hi all,
I'm looking at buying BC Racing Coilovers type BR and I was wondering what spring rate to go for.
What is the standard spring rate? Does anyone know what the spring rates are for the lesjofors springs that come with the Koni kit? As i've been running these for the last 8 years...
Many thanks
Alex
Back to top
User is offline
Lauren
PostPosted: Mon Mar 06, 2017 7:26 pm    Post subject: Reply with quote Reply with quote including images
Generally the spring rates for coilovers are a fair bit higher than they would be for stock. But better damping doesn't necessarily mean a harsher ride. BC offer three options for spring rates. 5/8kg seems the likely option. For a slightly easier ride 4/7kg, or 4/6kg may be preferable, though I'm not sure that BC offer custom spring rates like say, Tein do. I would generally want to reduce the difference between front and rear a bit. I went for 6/5kg from Tein for my AE86, but I had them made to spec.
I don't know the stock spring rates but they will be low, like 2/3kg or some such.
http://www.bc-racing.co.uk/applications/toyota-coilovers/toyota-mr2-aw11-86-89/br-series-coilover-type-ra-4.html
_________________
1985 AE86 Sprinter Trueno GT-Apex [lover]
2013 GT86 Miltek Exhaust, decat/overpipe Injen Induction. Volks Racing TE37s & TRD Aero Fins, Mega sounds. TEIN Street Flex 5/6kg, TEIN EDFC Active Pro. Tuning Developments Remap [lover]
Back to top
User is offline
Lauren
PostPosted: Mon Mar 06, 2017 8:04 pm    Post subject: Reply with quote Reply with quote including images
Some useful info here perhaps:
https://www.mr2australia.com/mr2play/tm.aspx?m=44056
Back to top
User is offline
SuperRedMR2
PostPosted: Tue Mar 07, 2017 9:37 am    Post subject: Reply with quote Reply with quote including images
I'm also struggling to find OEM bushes for the rest of my suspension.
Don't think polybushing will be a good idea.
Back to top
User is offline
Gazza_DJ
Premium Member
1997 Toyota MR2 Mk2 NA Rev4
PostPosted: Tue Mar 07, 2017 10:02 am    Post subject: Reply with quote Reply with quote including images
BC do offer some spring options but it seems to be specific to the model. For example I have 4/6KG on my Mk2 which is an option on the BR's.
Back to top
User is offline
Lauren
PostPosted: Tue Mar 07, 2017 12:23 pm    Post subject: Reply with quote Reply with quote including images
Polybushing doesn't really make it harsher as such. I take it you've tried Toyota. You never know and all that.
Back to top
User is offline
Gazza_DJ
Premium Member
PostPosted: Tue Mar 07, 2017 12:29 pm    Post subject: Reply with quote Reply with quote including images
If it's anything like the Mk2 then the bushes may only be available as a complete assembly with the arms = expensive!
Polymer tech has come a long way since the Max Power days, modern polybushes are a lot better than they used to be.
Back to top
User is offline
Display posts from previous:
Post new topic   Reply to topic       www.imoc.co.uk Forum Index -> MR2 MK1 1984-1989 NA & SC All times are GMT
Page 1 of 1
Jump to:
