What alloys people using?
CurtisRW
Post by CurtisRW »
So I've just bought a mk1 and the one of the rear OEM wheels is cracked so I am looking to replace all the wheels.
Just wondered what other people were rocking?
Also, any recommendations on where to buy alloys?
Include pics if you've got any :D
Tiamat
Re: What alloys people using?
Post by Tiamat »
What alloys are they?
I know I have a couple of MK1a alloys in the shed.
Mine currently runs on Toyota Paseo wheels, same size as originals but much better looking. Will try and find a pic.
Essex2Visuvesi
Post by Essex2Visuvesi »
seen a few with the MK3 Roadster wheels
Same Offset and stud pattern only 15"
User avatar
Lauren
Post by Lauren »
Offset isn't as good on the Roadster wheels and they corrode badly. Cheap but a bit of a meh option.
Get some proper JDM wheels on there! Think Rays, Work, Enkei, Wedsport etc if you want an authentic look. Reduce the offset a bit and it will look better and increase the track slightly.
Essex2Visuvesi
Adavan SA3Rs would look epic
Bloody hard to find in 4x100 tho. Took me 9 months to find my set
Angpozzuto
Post by Angpozzuto »
Essex2Visuvesi wrote:Adavan SA3Rs would look epic
Definitely an awesome look I love mine
Or work miester s1r
Essex2Visuvesi
Image Replaced With URL For Quote [url]http://i304.photobucket.com/albums/nn194/angpozzuto/619F81A0-FAA2-4E48-9579-39B66995E508_zpsxs2tnsgz.jpg[/URL]
Or work miester s1r
Image Replaced With URL For Quote [url]http://i304.photobucket.com/albums/nn194/angpozzuto/485A3383-5EE0-467B-9D91-580D3DBB78A1_zpsh3pzul6v.jpg[/URL]
Mine are going onto a MK3 when they come back from the refurbishers
Charged
Post by Charged »
I love the advans usually but I don't think they work on a Mk1. I like your Works, can I ask what size and offset they are?
Angpozzuto
Really?? I think they suit the mk1 more than the mk2
The work wheels are:
7j x 16 et20 front
8j x 16 et30 rear
The fitment is quite flush and could really do with getting the arches rolled as they scrub the lip of the arches over bumpy roads
Charged
Post by Charged »
7j x 16 et20 front
8j x 16 et30 rear
Thanks for that. One last question, where did you buy them from?
And yeah, I prefer the look of the three spokes on a Mk2 over on a Mk1.
Angpozzuto
Charged wrote:
7j x 16 et20 front
8j x 16 et30 rear
I ordered them from driftworks and had to wait for 2 months for them to be made and shipped
kaiowas
Post by kaiowas »
Or work miester s1r
Had my eye out for a set for the wifes mk3 for a while, they'd need to be in the original finish with the red lip though which makes them even harder to find
I've just fitted 13x8 Compomotive CX-R in satin black to the mk1, looks properly aggressive now but I need to get the faded paint sorted
Essex2Visuvesi
Indeed
Thats the ones I have
After buying from japan, associated fees/duty, refurb to factory black/red rim and new tyres I think i'm into them for about 1200quid :oops:
And they are going on a car that cost me less than 700 :shock:
autobody
Premium Member
Post by autobody »
Not the best pic but here are mine alloys, Piaa Nakajima Racing 3 piece split rims.
CurtisRW
Post by CurtisRW »
Thanks for the response.
Quick question, how well do 7" width's fit since the stock ones are 6J just wondering if a 7J 15" will fit
User avatar
Lauren
Post by Lauren »
7" is fine. I would go 7.5" with a 195/50/15. I've done this on my AE86*.
*I haven't tried 7.5" on an MR2, it's been a long time since I've owned one now. But I don't see why it would be an issue. Get the offset right though. You'll likely want to reduce it over stock by 10mm.
CROOKY1811
Post by CROOKY1811 »
Image split rims on mine,were about 2k with the tyre's fitted,10 yrs old now and still look brand new.
Charged
Post by Charged »
Hi Phil,
have you got any pictures? What offset did you go for and do they fit over standard brakes?
Ollie
kaiowas
Post by kaiowas »
Not got any proper pics yet but the wheels themselves clear the brakes ok (Standard mk1b at the front, mk2 22v calipers on mk1b front discs at the rear) although I do have to be careful with the placement of any balance weights on the rear. I'm running zero offset with bolt on arch extensions although there's a fair bit of clearance on the suspension so you could run a positive offset to tuck them in a bit and maybe get them under standard arches if need be.
oukie
IMOC Organiser
Post by oukie »
On my SC I'm running genuine, JDM Work RSB Ewing' s
On my n/a, I'm running BSA racing Cobra's
Chris
Mk1b White T-bar SC 1987, Mk1b White coupe Jan90, Mk1b White coupe Jan90 (spares), Mk1b Mica blue T-bar Mar90, Mk1b Mica blue T-bar,full climate control,Jan90, 5 mk1's :)
