[Mk2] [Turbo] Are catalytic converters universal?
Caleb-mr2
Post by Caleb-mr2 »
Hi,
I need a catalytic converter for a rev 5 turbo. Would a rev 2 turbo cat work or are the exhausts a bit different?
Caleb-mr2
Re: [Mk2] [Turbo] Are catalytic converters universal?
Post by Caleb-mr2 »
Bump. Anyone know if they're all the same?
androo007
Post by androo007 »
I'm not certain on Rev 1&2, but can say with a degree of confidence that the Rev 3+ cats will work.
markstevieandmads
Post by markstevieandmads »
Im thinking the decats all work ok with each other though the stud may need to be removed as rev 1&2 have 6 and rev 3 plus has 7.
Caleb-mr2
Post by Caleb-mr2 »
androo007 wrote:I'm not certain on Rev 1&2, but can say with a degree of confidence that the Rev 3+ cats will work.
I thought the same.
Are the 6 studs the same pattern as the 7 stud minus the obvious extra stud?
markstevieandmads
Yes they are. Hence u can use a ct20b turbo on a rev1/2 etc
